Canedje
How to create /etc/exports for NFSv4?
Sat Nov 19, 2016 10:16 am
I don't understand how to configure for the new NFSv4?
In the exportsfile there is an example:
# Example for NFSv4:
# /srv/nfs4        gss/krb5i(rw,sync,fsid=0,crossmnt,no_subtree_check)
# /srv/nfs4/homes  gss/krb5i(rw,sync,no_subtree_check)
My old exports did looks like:
/home/ewh 192.168.2.0/24 (rw)
Please help to change my old export to the new standard
PeterO
Re: How to create /etc/exports for NFSv4?
Sat Nov 19, 2016 10:30 am
I just checked on my MINT-17 machine, and it seems to be using NFSV4 and my /etc/exports file looks like it always did (i.e. the V3 example )
Have you tried it ?
PeterO
Canedje
Sat Nov 19, 2016 10:45 am
Yes. But not working I do have allready several days trouble mounting
Sometimes it works. Most off the times not
I re-installed severall times everything. Sometimes it works then, sometimes not.
If it works it is until a updat/upgrade
It makes me crazy
PeterO
Sat Nov 19, 2016 11:27 am
How does it fail ? Anything in log files when it works or fails ?
PeterO
Canedje
Sat Nov 19, 2016 11:51 am
Thats one off the problems.
There are not realy error files for mounting.
if I try to mount:
sudo mount -v -t nfs 192.168.2.202:/home/ewh /mnt/PI
mount.nfs: timeout set for Sat Nov 19 12:49:29 2016
mount.nfs: trying text-based options 'vers=4,addr=192.168.2.202,clientaddr=192.168.2.185'
mount.nfs: mount(2): Connection refused
sudo exportfs at the other RPI shows:
sudo exportfs
/home/ewh       192.168.2.202
/home/ewh       <world>
The nfs kernel is running
RPCbind is running
That all looks correct
EDIT:
It is running again.
It looks like something is wrong after update/upgrade with the nfs kernel
If I do:
sudo /etc/init.d/nfs-kernel-server restart
The mount is working again
