solo2500
passing data from .py to .sh
Thu Nov 17, 2016 3:10 pm
I know very little about programing so please bare with me!
I'm trying to pass some data from a python program to a shell script. I understand one option is to "call" the shell script from within the python program. I have tried the following but I'm getting an error.
#Python 2.7.9 (default, Mar  8 2015, 00:52:26)
#[GCC 4.9.2] on linux2
#Type "copyright", "credits" or "license()" for more information.
#!/bin/python
#program to read temp.txt file and deliver...
f = open('/var/www/axx/temp.txt')
line1 =f.readline()
line2=f.readline()
f.close()
print 'line1',line1
print 'line2',line2
call(['bash', 'overlayv2.sh', line1, line2])
The result includes this error:
line1 11/15/2016 05:15:00 PM
line2 50.0F
File "/home/pi/axx/datatransv1.0.py", line 32, in <module>
call(['bash', 'overlayv2.sh', line1, line2, line3])
NameError: name 'call' is not defined
Can someone explan what I'm doing wrong?
Also, If there is a better (easrer) way I'm all ears!
THANKS FOR ANY HELP!!!
I'm a total novice, non-programer (...basically a hack.)
SkyRise
Re: passing data from .py to .sh
Thu Nov 17, 2016 3:26 pm
You want to use subprocess.run, like
subprocess.run(["ls", "-l"])
And see the docs at
https://docs.python.org/3/library/subprocess.html
solo2500
Thu Nov 17, 2016 3:46 pm
I get the same error when I try this:
subprocess.run(['overlayv2.sh', line1, line2, line3])
Or this:
subprocess.run(['bash','overlayv2.sh', line1, line2, line3])
SkyRise
Thu Nov 17, 2016 4:02 pm
Sorry, hadn't noticed that you're using python 2.7
It did used to be 'call':
subprocess.call(["ls", "-l"])
See python 2 docs here
https://docs.python.org/2/library/subprocess.html
solo2500
Thu Nov 17, 2016 4:34 pm
Thanks... back to original question... what am I doing wrong?
SkyRise
Thu Nov 17, 2016 4:51 pm
You're using
instead of
subprocess.call(['bash', 'overlayv2.sh', line1, line2])
The 'call' function is part of the 'subprocess' package. Which does raise another point, you'll need to import the 'subprocess' package in order to use its functions (at the top of your code)
import subprocess
solo2500
Thu Nov 17, 2016 11:25 pm
Ok... making progress...
adding
import subprocess
eliminated the error... and the shell script runs but it doesn't seem to pass the contents of line1, line2 etc?
Any ideas...?
solo2500
Fri Nov 18, 2016 5:50 pm
anybody? anything?
Return to “Beginners”
