Looking to import a large CSV file into MYSQL on my pi3 to be used as part of a project I'm working on.
The issue I'm running into is that the MYSQLIMPORT appears to be hitting the 32bit limits MS Excel use to have, and as a result, I'm only getting 375771 records instead of the 1452138 records contained in the csv.
The file is ~108mb in size. Not huge, no odd characters
My memory may be failing me, but I could have sworn I had exceeded this limit back when I was using Slackware 7.
the command I'm using
mysqlimport --ignore-lines=1 --fields-terminated-by=',' --local -p celltower /home/pi/extract.csv
