Windcheetah
Soldering with only left arm.
Mon Nov 14, 2016 7:19 pm
Hi everyone, I have been run down by a transit van while on my bicycle.
This caused me to have no feeling or movement in my right hand.
The question is, has anyone mastered soldering with 1 arm/hand??
Pi's are topps!!!!
Martin
Pies are topps!!!!!
mikronauts
Re: Soldering
Mon Nov 14, 2016 7:29 pm
Sorry to hear about your accident!
1) Look for pcb holders http://ca.mouser.com/Tools-Supplies/Too ... /_/N-11uop
2) buy/make some sort of "solder pen" that you can hold/direct with your mouth http://www.digikey.ca/product-detail/en ... ND/2177387
3) get some safety glasses
4) ideally also get a fume extractor
Windcheetah wrote:Hi everyone, I have been run down by a transit van while on my bicycle.
Pi's are topps!!!!
Martin
gregeric
Re: Soldering
Mon Nov 14, 2016 7:41 pm
Hi Windcheetah. As well as the above, maybe it's worth trying soldering paste instead of solder. Apply a blob of paste to the joint, then pick up your iron & melt it.
Windcheetah
Re: Soldering
Wed Nov 16, 2016 1:20 pm
Thanks loads for the suggestions.
Martin
Pies are topps!!!!!
KMyers
Re: Soldering
Thu Dec 01, 2016 6:16 pm
Sorry about your accident. I was also in an accident in 2004, hit and run type. Was an RF engineer who liked to build things (solder). Was very difficult to solder using one hand. I find the most help comes from holding the board secure with tape, using a magnifying lite and smallest solder. I can do it but it takes much longer then before. Also if you can get a variable temp iron.
Good luck keep soldering! :D
Ken N8SYG
lpsw
Re: Soldering
Thu Dec 01, 2016 6:44 pm
Hi Windcheetah. Sorry to hear about the accident. gregeric's suggestion is what I've been using for a while. Had a little issue after a fall climbing in Scotland in 1987. Been soldering with mouth and left had hand since then, until I found soldering paste.
gregeric wrote:Hi Windcheetah. As well as the above, maybe it's worth trying soldering paste instead of solder. Apply a blob of paste to the joint, then pick up your iron & melt it.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
Windcheetah
Re: Soldering
Thu Dec 08, 2016 10:41 am
Thanks very much for your thoughts, I think I'll give the solder paste a shot.
Martin
Pies are topps!!!!!
Return to “Assistive technology and accessibility”
