goose2000
Back to command line login ?
Wed Sep 05, 2012 11:34 pm
Hi, I setup my RPI to boot with an interface (startx). No I have some new goals and want to boot into the command line. Is there a way I can change that or do I need to re-do the SD card all over?
Or, is there a way to exit the login screen, and go to command line?
Licaon_Kter
Re: Back to command line login ?
Thu Sep 06, 2012 12:54 am
CTRL-ALT-F1 -> to command line, login, then run 'service stop lightdm' to stop the login manager
for the next time edit sudo nano /etc/inittab and there should be a default something like id:5:initdefault:
that you change to id:3:initdefault:
more info: http://elinux.org/RPi_Debian_Auto_Login
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
goose2000
Thu Sep 06, 2012 2:21 am
Excellent! Thought that should be doable.
Thanks to Licaon_Kter
spitecho
Thu Sep 06, 2012 3:13 am
You can also run sudo raspi-config and change the "boot_behaviour" setting.
Licaon_Kter
Fri Sep 07, 2012 8:50 am
yeah of course, I forgot about that :?
psutton
Wed Sep 12, 2012 8:28 pm
I would suggest learning both methods, using raspi-config sounds great (so thanks for that) , but at least by learning the manual way you get an understanding of what the config program is doing, and know where to look if it fails to do what you expected.
