fgfanta
How to revert to previous firmware
Sun Nov 13, 2016 8:40 pm
After updating to the latest firmware of a Raspberry PI 2 B with
sudo rpi-update
I am getting some flickering on screen, icons on the desktop moving around, and an intermittent yellow bolt in the top right corner.
I understand I can revert to some previous firmware with
sudo rpi-update <hash>
but which value should I use for <hash>? Where can I check the latest stable firmware release to be used?
The Raspberry is connected to a BrickPi. I had previously updated the software with
sudo aptitude full-upgrade
Thanks!
Re: How to revert to previous firmware
Sun Nov 13, 2016 8:44 pm
https://github.com/Hexxeh/rpi-firmware/commits/master
Or better
sudo apt-get install --reinstall raspberrypi-kernel
Stop running rpi-update, stick with the stable kernel.
This is a doctor free zone.
fgfanta
Mon Nov 14, 2016 9:37 pm
When I try with apt-get, I get:
E: Unable to locate package raspiberrypi-kernel
I assumed a typo in the package name and also tried raspberrypi-kernel, with the same result.
Thanks.
Mon Nov 14, 2016 9:39 pm
My system has this
[email protected] ~ # dpkg -l | grep raspberry.*kernel
ii  raspberrypi-kernel                    1.20161020-1                              armhf        Raspberry Pi bootloader
fgfanta
Wed Nov 16, 2016 12:10 am
I have re-imaged the micro SD with the latest Raspbian and now the problem is resolved. Previously I had a very old image on the micro SD, hence the unexpected output of dpkg -l | grep raspberry.*kernel.
Thank you for your help!
