Mike-DC
how can i mask an area with picamera motion vectors
Sun Nov 13, 2016 4:51 pm
Hi
I am pretty new to the raspberry and am playing with the camera and motion detection using waveform80's picamera python module.
I am using a motion resolution of
motion_width = 1296
motion_height = 730
but an area of the frame suffers a lot of light reflection triggering motion detected at pixel offsets approximately 0,260 to 500 760
if I turn the sensitivity up and/or threshold up to stop the motion being detected in this area then the remainder of the frame is not sensitive enough.
is there any way I can mask this area from motion detection ?
I guess I need to apply a mask somehow to this piece of the code
# calculate length of motion vectors of mpeg macro blocks
a = np.sqrt(
np.square(a['x'].astype(np.float)) +
np.square(a['y'].astype(np.float))
).clip(0, 255).astype(np.uint8)
Regards
Mike
BerryPicker
Re: how can i mask an area with picamera motion vectors
Tue Nov 15, 2016 9:42 am
If the trouble is at the picture edge, you could specify a region of interest to zoom in.
6by9
Tue Nov 15, 2016 11:50 pm
You are correct that there is no existing mechanism to do this, and you need to alter the loop that calculates the length of motion vectors of mpeg macro blocks.
Read the docs:
Motion data is calculated at the macro-block level (an MPEG macro-block represents a 16x16 pixel region of the frame), and includes one extra column of data. Hence, if the camera’s resolution is 640x480 (as in the example above) there will be 41 columns of motion data ((640 / 16) + 1), in 30 rows (480 / 16).
So if you've set it to 1296x730, then your motion vector array is going to be 82 x 46 elements. Manipulate the data to ignore the values in your dodgy region before you average them or count number above a threshold. Or it may be simpler to 0 your mask and then use the existing code unmodified.
i234
Sun Apr 02, 2017 2:01 pm
6by9 wrote: ...
Where does this “one extra column of data” come from?
What does it correspond to?
Thank you.
Return to “Camera board”
