laserman
Starting a program and viewing in VNC
Sun Nov 13, 2016 12:25 pm
When my Raspberry Pi starts, I have a line in /home/pi/.config/lxsession/LXDE-pi to autostart a program. Opening a terminal, typing top, I see the program running but when I access the pi via VNC, I am not able to see the program GUI. I can connect a monitor and see it there but not virtually.
How can I get it to where I can see the program from VNC?
laserman
pi-anazazi
Re: Starting a program and viewing in VNC
Sun Nov 13, 2016 1:16 pm
VNC normally on Linux starts on a display other than the one you see on your monitor, e.g. you start your vncserver on :1 and you access it via 10.10.10.25:1.
If you want the same display as on the monitor, use display :0, but you need special setup for this (only on Windows :0 is default, no other displays possible, iirc).
Kind regards
anazazi
Martin Frezman
Sun Nov 13, 2016 1:19 pm
The answer to your question is:
x11vnc
That's the version of VNC that "mirrors" the "real" display, rather than creating a new, "virtual", display.
BTW, I think the new, "RealVNC", version of VNC might also figure into this, but I have not had a chance to test it yet.
If this post appears in the wrong forums category, my apologies.
Sun Nov 13, 2016 2:09 pm
Martin Frezman wrote:The answer to your question is:
x11vnc
An updated Raspbian Jessie includes RealVNC which may be suitable:
https://www.raspberrypi.org/blog/introducing-pixel
RPi 4B 4GB (SSD Boot)..
laserman
Wed Nov 16, 2016 1:02 pm
Appreciate the replies. I will check into the new RealVNC.
laserman
Return to “Advanced users”
