I have a RPi 3b that I have accessed via terminal using 'ssh pi@raspberrypi.local' so I know it is connected to my computer.
In the network preferences I have the configure IPv4 set to 'using DHCP' and location 'automatic' but when I run any internet commands (ie. 'sudo apt-get update') I always get these failed to fetch and could not resolve errors
my route says:
pi@raspberrypi:~ $ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
link-local * 255.255.0.0 U 202 0 0 eth0
my ifconfig says:
pi@raspberrypi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:1f:19:fd
inet addr:169.254.194.54 Bcast:169.254.255.255 Mask:255.255.0.0
inet6 addr: fe80::593c:fe18:5d19:feef/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:326 errors:0 dropped:0 overruns:0 frame:0
TX packets:210 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:48087 (46.9 KiB) TX bytes:34870 (34.0 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:448 errors:0 dropped:0 overruns:0 frame:0
TX packets:448 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:36544 (35.6 KiB) TX bytes:36544 (35.6 KiB)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:4a:4c:a8
inet6 addr: fe80::d7cf:b4d3:3be9:467b/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:2352 errors:0 dropped:2352 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1125965 (1.0 MiB) TX bytes:0 (0.0 B)
Does anyone know why I can't access the internet??
