First of all, this is my first post here, so sorry if I do anything wrong
I have a Raspberry Pi 3 (first time using one of these) and i managed to install the OS on a SD card and run it on the raspberry.
I connected to it via Putty>vnc viewer (I don't have a hdmi monitor, only a laptop)
Everything worked fine. i connected to it multiple times.
But then I turned it off (using shutdown) and now I can not connect to it anymore.
It does not get an IP address (I scanned using advanced ip scanner)
The LEDs are on (red always on and green blinking every once in a while)
When i plug it in my laptop's LAN port a new LAN connection appears in network manager.
I reinstalled the Raspbian on the SD card but still can't connect.
Can you help me in any way to connect to the Raspberry please?
If you need any more info, just ask.
Thank you very much in advance.
