PieterG
Disable IPv6
Thu Nov 10, 2016 5:00 pm
My rPI3 is behind my own router in an IPv4 network only.
Raspbian (Debian Linux 8.0) is installed and as well as Webmin 1.820 and Virtualmin 5.04
That works all fine.
I have a monitor tool that probes external sites for their availability and up time. Again, so far so good.
Though in my syslog I see errors like
error (address not available) resolving 'domain.com/DS/IN': 2001:7c8:605::85#53
To me that seems it is trying to resolve a domain to an IPv6 address.
As my local network is IPv4 only this is not gonna work.
IPv6 in Debian (and other distros) is preferred by default. So I tried changing the priority
Tried disabling in several ways. From disabling in Bind9 to disabling it completely on boot.
See the info I used thusfar.
http://askubuntu.com/questions/32298/pr ... v6-lookups
viewtopic.php?f=36&t=138899
https://wiki.debian.org/DebianIPv6#How_to_turn_off_IPv6
http://askubuntu.com/questions/309461/h ... ermanently
(Ubuntu being comparable to Debian)
Anyone that can shine a light on what I missed out on or did wrong? Or just don't understand, me being the noob... ;)
Tx,
Gerd
Re: Disable IPv6
Fri Nov 11, 2016 9:52 am
viewtopic.php?f=36&t=138899 should shed some light on this
PieterG
Re: Disable IPv6
Fri Nov 11, 2016 8:06 pm
None of the proposed solutions in that link worked.
malicious
Re: Disable IPv6
Sat Nov 12, 2016 2:00 am
Configuring IPv6 support in the kernel and user space applications are separate. Settings such as
net.ipv6.conf.all.disable_ipv6
net.ipv6.conf.default.disable_ipv6
etc.
set IPv6 kernel support but applications will try to use IPv6 regardless if configured to do so. Whatever program is generating those syslog error entries will need to have its own settings adjusted.
Re: Disable IPv6
Sat Nov 12, 2016 10:05 am
Personally, I'd leave it alone as it fails quietly. Some time in the next twenty years we may all switch to the twenty year old "new" IPv6 protocol (which is already running on my network with a Hurricane Electric tunnel on my RPi B+).
It may be better to build your own HE tunnel rather than disabling IPv6.
https://tunnelbroker.net/
Other brokers are available
https://en.wikipedia.org/wiki/List_of_I ... el_brokers
Some ISPs have begun the switch to IPv6 and it will "just work" without any changes.
This is a doctor free zone.
PieterG
Re: Disable IPv6
Sat Nov 12, 2016 10:11 am
It is "named" (bind9) that fails "quietly".
So because the target domains do not have an IPv6 address (yet) it fails? Is that correct?
It now says "error" it should be "info" then right?
Anyone knows a way to disable this message in the log file (or at least change it to "INFO")?
Re: Disable IPv6
Sat Nov 12, 2016 10:37 am
Have you got the forwarders and/or root servers defined in your /etc/bind/named.config.options?
options {
        forwarders{
        // GoogleDNS
                  8.8.8.8;
                  8.8.4.4;
 // ... other stuff goes here ...
// prime the server with knowledge of the root servers
zone "." {
        type hint;
        file "/etc/bind/db.root";
PieterG
Re: Disable IPv6
Sat Nov 12, 2016 12:56 pm
That's IT! setting forwarders.
I actually thought it would pick up the DNS from the network settings (as there is DNS set there)
Apparantly not.
Thanks!
Return to “Raspbian”
