xiaozai
Append text to text file with timestamp
Thu Nov 10, 2016 10:26 am
I want to append the output from a python code into a text file. Above is my python code and i loop it for every 2 hour
if response == 0:
    print(hostname, "is up")
    if option == 1:
       print(option, "is the option')
       print('this is option number 1')
    elif option == 2:
       print('this is option number 2')
    else:
       print(option, "is the other option')
       print('this is the result of other option')
i notice that i need the following code to append the result to a text file.
with open("test.txt", "a") as myfile:
    myfile.write("appended text")
How can i record every output to a text file and include time stamp to it? for example
09:10  192.168.0.1 is up
09:10  1 is the option
09:11   this is option number 1
11:15  192.168.0.1 is up
11:10  1 is the option
11:11   this is option number 1
13:10  192.168.0.1 is up
13:10  3 is the other option
13:11   this is the result of other option
scotty101
Re: Append text to text file with timestamp
Thu Nov 10, 2016 11:52 am
This seems like it would be a good candidate for the built in python logging module rather than spinning your own version using print or writing to a file.
https://docs.python.org/3/howto/logging.html
You can modify the format of the log to display a time stamp before each entry.
scotty101
Thu Nov 10, 2016 11:55 am
Here is a very basic example of setting up the logger and setting the format with a time/date stamp
import logging
logging.basicConfig(filename='example.log',level=logging.DEBUG, format='%(asctime)s %(message)s')
logging.debug('This message should go to the log file')
logging.info('So should this')
logging.warning('And this, too')
Return to “Python”
