MrJansson
Incorrect/random touch response
Thu Nov 10, 2016 10:21 am
I've run into a problem with the RPI official 7" touch display. I use the display in landscape rotation. When I press anywhere, it returns numerous touches in sequence but all on the same Y-position value but with random X. It seems that it cannot determine where I put my finger horisontally.
Anyone who has experienced the same thing? I will upload a video later on where I show the problem.
scotty101
Re: Incorrect/random touch response
Thu Nov 10, 2016 1:20 pm
Which option did you add to the /boot/config.txt file to rotate the screen?
You should have used lcd_rotate rather than display_rotate
MrJansson
Fri Nov 11, 2016 9:12 am
standard Windows 10 IOT config with lcd_rotate=2
