bren0
Problem network
Mon Nov 07, 2016 7:56 pm
I created a WiFi network from Raspberry PI. (Raspberry PI is a WiFi router)
IP Gateway: 192.168.0.1
eth0 IP: 192.168.0.101.
IP wlan0: 192.168.42.1
The Raspberry is connected to a router, which has another computer connected via cable (192.168.0.107).
I have other devices connected to the network created from Raspberry, with IP 192.168.42.79 and 192.168.42.65.
What I have to do to the IP 192.168.0.107 able to communicate with the IP 192.168.42.79 or 192.168.42.65?
P.S.: I'm using the Google Translator.
epoch1970
Re: Problem network
Tue Nov 08, 2016 10:02 am
The frilip.com blogpost has you covered in section "SET UP IPV4 FORWARDING"
bren0
Re: Problem network
Tue Nov 08, 2016 11:11 am
epoch1970 wrote:The frilip.com blogpost has you covered in section "SET UP IPV4 FORWARDING"
I followed this tutorial to turn my raspberry in access-point.
epoch1970
Re: Problem network
Tue Nov 08, 2016 12:54 pm
Sorry I misread what you were asking.
I think you should remove the masquerade option in iptables on the Pi. That way, each computer behind the Pi will retain its own IP address. (*)
The Pi has an interface on each network and routing is enabled, so I think it is good to go.
Client computers on the 192.168.0.0 network need to know where the gateway to the 192.168.42.0 network is. In other words, they need a static route to that network via 192.168.0.101.
So you need to do something like (depending on client OS) "ip route add 192.168.42.0/24 via 192.168.0.101 dev eth0" on each client.
To automate it, perhaps you can add that to your router's DHCP server configuration (or use a dhcp server like dnsmasq listening on 192.168.0.101 as a replacement to your router's service; dnsmasq understands dhcp option 121).
In case you want to let hosts on 192.168.42.0 reach the internet: I suppose outgoing traffic will pass ok without any change to the edge router's configuration. For incoming traffic (and possibly responses), the edge router will need a static route also, to send traffic back to those foreign hosts on 192.168.42.0, via 192.168.0.101
(*) If you retain the use of masquerading, you don't have to worry about routing to a second network. However, you'd need to define port forwarding on the Pi, so that for example a hit to 192.168.0.101 port 1234 from a client computer would be forwarded to 192.168.42.65 port 22. That's ok for a few services, but beyond that managing forwarding rules get cumbersome.
Pick your poison...
