sjfujiang
how to control “sg90” Steering engine
Sun Nov 06, 2016 12:21 pm
http://www.besthobbysite.com/ebaystoreV3/image/SG90.jpg
how to control “sg90” Steering engine?
“GpioPinValue pinValue = GpioPinValue.Low;
pin27 = gpio.OpenPin(27);
pin27.SetDriveMode(GpioPinDriveMode.Output);
pin27.Write(pinValue);”
but sg90 does not work。
Major Tom
Re: how to control “sg90” Steering engine
Sun Nov 06, 2016 12:33 pm
It's a servo motor.
You need to generate servo control pulses on the signal wire (orange).
I recommend you start with pigpio.
You can read about pigpio here:
http://abyz.co.uk/rpi/pigpio/
For a quick test, start the pigpio daemon:
sudo pigpiod
Then use pigs to generate the servo pulses:
pigs SERVO 27 1500
Here, 27 is the GPIO number, and 1500 is the pulse width in microseconds. 1500 represents the "centre" position of the servo.
My circuit's dead, there's something wrong.
Sun Nov 06, 2016 1:04 pm
Slight problem, pigpiod and pigpio is Linux only, it doesn't exist on Win10 IoT.
Major Tom
Sun Nov 06, 2016 1:13 pm
DougieLawson wrote:Slight problem, pigpiod and pigpio is Linux only, it doesn't exist on Win10 IoT.
You know, you're right. The sub-forum is not easily visible on the "New Posts" page. I'll double-check that next time before I post.
Anyway, maybe someone can help with Win10, or maybe the original poster will try Raspbian.
CAP-XPLAB
Sun Nov 06, 2016 2:08 pm
perhaps can help: two projects make use of SG.
https://www.hackster.io/powerberry
Return to “Windows 10 for IoT”
