Hi all,
Trying to run a Java JNLP file which used to load up in around 2 minutes using a Pi 2 with the following Java:-
Java version 1.7.0.40
java™ se runtime environment (build 1.7.0_40-b43)
java hotpot™ client vm build 24.0-b56, mixed mode)
Iced Tea 1.4 (1.4.3~deb7u2)
I have tried running the same JNLP with a Pi 3 and it takes over 8 minutes to load up from the JNLP and the CPU consistently hangs at 100% with the following Java version:-
java version "1.7.0_101
OpenJDK Runtime Environment (IcedTea 2.6.6) (7u101-2.6.6-2~deb8u1+rpi1)
OpenJDK Zero VM (build 24.95-b01, interpreted mode)
Iced Tea 1.5.3 (1.5.3-1)
Would anyone know why this may be and if i need to run a different Java version or Icedtea version?
Cheers
