Flexx
RGB LED strip won't work with RPi 3
Wed Nov 02, 2016 4:50 pm
Hello again!
I cant change colour of my LED-strip with RPi. When my LED-strip is blue coloured and i want to change it to red for example, then it just wouldnt although from blue to light blue i can change and i see tiny difference. Ofcourse i followed the tutorial http://popoklopsi.github.io/RaspberryPi-LedStrip/#!/
but i have no clue what went wrong. Am i using wrong mosfets (irz44n) or breadboad: https://goo.gl/Z0X4Nx. Its a bit difference layout. Also one of my Mosfet bent a little but im guessing it doesnt matter if its connected correctly to breadboard? If i want to get different colour then i have to change combination on breadboard.
My question is, why wouldnt it work? (I also ordered TIP120 just in case)
scotty101
Re: RGB LED strip won't work with RPi 3
Wed Nov 02, 2016 5:09 pm
We won't know without some more information
viewtopic.php?p=1050518#p1050518
Flexx
Wed Nov 02, 2016 9:14 pm
1. I was following the tutorial.
Link : http://popoklopsi.github.io/RaspberryPi-LedStrip/#!/
2. The codes i used: pigs p 17 255, pigs p 22 255, pigs p 24 255
When i tried to change colour from red to blue for example, then it didnt change at all. So i tried to change from blue ( pigs p 24 255 to pigs p 24 50) i only noticed a little change but that was it.
3. Some pictures:
These wires are (-), (didnt have black ones so i had to make them like that)
Commands that i used
Lights turned on instantly after i connected power to breadboard (Couldnt change led colour with commands)
After changing combination on breadboard, LEDs changed colour
Some more pictures
4. Im using RPi 3 B model. The main problem is i cant change LED strip colours using RPi.
5. Only when i changed combination on breadboard, LEDs did change colour but that was it.
Flexx
Thu Nov 03, 2016 11:10 am
Hello again!
Can someone help me with this, im in a hurry.
Burngate
Thu Nov 03, 2016 7:17 pm
Flexx wrote:Hello again!
Flexx wrote:1. I was following the tutorial.
3. Some pictures:
-- image --
-- image --
-- image --
-- image --
-- image --
Some more pictures
-- image --
-- imag e--
That FET should be ok. So should the breadboard. I'm not sure which type of LED strip you've got, or what that tutorial is for.
Some things to try, possibly:
To take the Pi out of the equation as far as possible, move the three GPIO leads from the GPIO pins to ground pins - pins 6, 9, 14, 20, 25, 30, 34, 39 are all ground
- the LED strip should go dark (unless my brain has died, in which case it should glow white)
Then, one at a time, move those leads to a 3v3 pin - pin 1 or 17 - and back to ground
- the LED strip glow red/green/blue in turn (unless my brain has died, in which case it should glow cyan/magenta/yellow)
Moving two leads to to 3v3 should give you the opposite colours.
If any of that doesn't work, you've got a wiring problem
If that all works, try just moving one lead to a GPIO pin, and running the script. You should be able to change its intensity.
Move on from there to gradually build it up.
