xiaozai
Copy packet loss value in terminal into python
Tue Nov 01, 2016 6:00 am
i have the following code to ping a computer and copy the packet loss value from the ping result
 import os
            hostname = "192.168.0.255"
            packetloss = os.system ("ping -c 5 " + hostname+ " | grep -oP '\d+(?=% packet loss')")
            print (packetloss, 'is packet loss value')
The result that i get if 100% packet loss is
           (0, 'is packet loss value')
and if there is no packet loss
How can i make the above value the same? it always detect 0 on packet loss value.
rpdom
Re: Copy packet loss value in terminal into python
Tue Nov 01, 2016 6:25 am
os.system just returns the exit code of the command, which will be 0 (success) in this case. You should probably be using subprocess instead of os.system, but you could try os.popen for now
import os
packetloss = os.popen ("ping -c 5 " + hostname+ " | grep -oP '\d+(?=% packet loss)' ").read()
xiaozai
Tue Nov 01, 2016 6:30 am
change to os.popen. give me errors. "grep: write error: Broken pipe". i try to change to subprocess later
rpdom
Tue Nov 01, 2016 6:36 am
xiaozai wrote:change to os.popen. give me errors. "grep: write error: Broken pipe". i try to change to subprocess later
Funny, the code I posted above (now I fixed the indentation from your original), works for me
$ python testprog
('100\n', 'is packet loss value')
xiaozai
Tue Nov 01, 2016 6:42 am
my bad. there is typing error on my side. thank you for the code. work nicely :)
xiaozai
Thu Nov 03, 2016 6:12 am
just notice something. how can i eliminate "\n" from the packet loss value?
rpdom
Thu Nov 03, 2016 6:33 am
One way is to use rstrip()
import os
packetloss = os.popen ("ping -c 5 " + hostname+ " | grep -oP '\d+(?=% packet loss)' ").read().rstrip()
The '\n' is the Linux "newline" character and a simple internet search for "Python remove trailing newline" came up with loads of examples.
xiaozai
Thu Nov 03, 2016 6:40 am
is there gonna be an error if use this command instead?
print(packetloss.rstrip(), 'loss value')
rpdom
Thu Nov 03, 2016 6:45 am
xiaozai wrote:is there gonna be an error if use this command instead?
Try it and find out? ;-)
You might even want to try
print packetloss.rstrip() + ' loss value'
xiaozai
Thu Nov 03, 2016 6:46 am
already try it. hoping there are no error if i keep using this code. thanks alot :)
xiaozai
Thu Nov 03, 2016 8:10 am
Im confuse a little bit. i add another code:
if packetloss <= 10:
                   print(packetloss, 'is packet loss value')
                   print('this is below 10')
elif packetloss >= 11:
                   print('this is above 11')
else:
                   print('invalid number')
However every time i run the code, it always detect above 11 even though the loss value is 0. is there any coding error i have done?
elParaguayo
Thu Nov 03, 2016 8:33 am
My guess is that you are comparing a string value for packetloss with an integer.
Convert your string to an integer first.
Edit: this should illustrate the problem.
In [1]: packetloss = "0"
In [2]: packetloss <= 10
Out[2]: False
In [3]: packetloss >= 11
Out[3]: True
In [4]: packetloss = 0
In [5]: packetloss <= 10
Out[5]: True
In [6]: packetloss >= 11
Out[6]: False
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
