ldw
Chromium performance Raspi 2
Sat Oct 29, 2016 8:35 pm
I'm seeing poor (ish) performance of Chromium on my Raspi 2. I did take out the extension that killed ads, but that's the only change I've made. I'm not running multiple tabs - i see the cpu utilization get up to the high 80s often, and even pegged out at 100%. Is there something wrong with my Pi or is this the norm?
If so, I'm looking forward to Raspi 4. :)
kusti8
Re: Chromium performance Raspi 2
Sat Oct 29, 2016 8:43 pm
What websites? And why did you remove the ad blocker? That speeds up websites as well.
cjan
Sun Oct 30, 2016 12:54 am
why stay V51?
ldw
Sun Oct 30, 2016 5:30 pm
Websites: www.wired.com is a good example. I see my utilization go up to between 50 and 75% on that site. Even this one, as I type to post this message is showing between 30 and 45% utilization (on that little graph in the upper right on the tool bar).
If I start a term and look at top, with just this tab active in chromium, I see two processes taking most of the time, both Chromium. One is taking 100 to 117% of the cpu and the other taking 5 to 13%. Perhaps the 117% is multiple threads in that Chromium process, but I'm guessing.
If I open a second tab and go to wired.com the overall utilization goes up to 70%+. I see three Chromium processes, 180, 100 and 15%. (180 + 100 + 15)/4 = 74 .... close enough).
Adblocker: I removed the adblocker because it was showing up on Chrome on my Windows PC and many of the sites I went to were not happy with the ad blocker. Some actually failing in peculiar ways. So I removed it. I suppose I could sign out of Chromium and re-install the ad-blocker. But someone will have to tell me which adblocker came with Jessie/Chromium. I failed to notice as I removed it.
V51: Yes, I am using version 51 of Chromium. Are you suggesting there is another version that performs better?
ldw
kusti8
Sun Oct 30, 2016 5:38 pm
ldw wrote:Websites: http://www.wired.com is a good example. I see my utilization go up to between 50 and 75% on that site. Even this one, as I type to post this message is showing between 30 and 45% utilization (on that little graph in the upper right on the tool bar).
ldw
On a Pi2 that is around the norm. The Pi3 performs a bit better. The ad blocker was uBlock Origin BTW. You could still use Epiphany, but it is very buggy and unstable.
ldw
Tue Nov 01, 2016 3:52 pm
Thanks for the reply. I'll look forward to raspi 4. Hopefully it will have a good bump in memory and speed.
cjan
Fri Nov 04, 2016 1:24 am
cjan wrote:why stay V51?
found arch-arm chromium-V54 can play embed flash with HTML5.
Return to “Raspberry Pi OS”
