rpix86 wrote:DavidS wrote:If you do not mind something that may still have a couple of bugs, the new Puppy Linux Quirky for the RPi 2/3 does great with video playback.
Where does one download 'puppy linux quirky'?
The current version is at:
http://distro.ibiblio.org/quirky/quirky ... leases/rc/
Once you download it use unxz to extract the image, then write the image to the raw SD Card. Not sure what OS you are using to create the SD so can not give more specific instructions on writing the img to the SD. Though it is the same process as used to write any of the full OS's to SD (NOT noobs), so instructions are available on the Raspberry Pi site, just replace the img name with the one you get from extracting the downloaded xz.
Depending on your settings you may need to do some work on getting sound working. Though it is not to much (I had trouble at first, then just went back through it).
Also some people are having trouble getting WiFi working on this version of Puppy on the Raspberry Pi 3B. I am sure this will be sorted quickly though.
A lot more information is available on the Puppy Linux Forum in the anouncement thread for this version. This is the RC version that descusion begins on page 9 of the thread:
http://murga-linux.com/puppy/viewtopic.php?t=108132
So start with:
http://murga-linux.com/puppy/viewtopic. ... 832#928832
And there is some documentation linked by BerryK.
I hope this helps, puppy is a great Linux. I do not know if you have ever used Puppy Linux on other systems (like a PC), though it does have a few small things that take a little getting used to.
