Wed Oct 26, 2016 2:59 pm
Any tool that you want to layout your GUI. Just keep in mind that using a touch screen widgets should be large enough for the user to easily activate.
If you are using RISC OS then just use WinED or TemplEd. If you are using Linux the answer would depend on the GUI Toolkit you choose to use. If you are using one of the other non-unix like OS's then use what ever tool is appropriate.
I am making the assumption that you wish to design the application front end that uses an existing GUI, not design a new GUI from the ground up, as that would be a monumental task
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
