LordDiGio wrote:I have the same problem with the same keyboard. After firmware update at the boot the keyboard doesn't work, I have to unplug\plug again the usb receiver to make it work. The firmware is the last available (kernel 3.2.27 compiled on Sept 4). I have an old raspbian image and with it everything is fine, but after I update the firmware the problem shows up.
me too, same situation, same "solution" (unplug / plug receiver).
I started with the very old Debian supplied on SD-Card sold (all working), and switched yesterday to the actual Rasbian, availabe on the website.
I can't clearly say, when the problem occured first (before/after firmware update).
Seems to be a general problem with that combination.
