Hi folks,
I received my PI several days ago.
It runs with an Samsung SDHC 8GB (Class 6) and an Lexar Premium Series 4GB (Class 6) SD card
but not with an SanDisk Ultra 4GB (Class 4).
But sometimes it will not boot. Only the red led is on without any flashing green led (Power supply is ok >1A and 4.85v between TP1 and TP2).
First, I thought that I have a problem with the SD cards.
But then, I inspected the SD card slot and the apropriate contacts on the PI board.
I tested the contacts of the SD card slot with a DVM.
And I found 2 cold solder joints. The SD card slot was not properly soldered onto the board.
I gave my PI into the refrigerator - and - it works again (be careful - avoid moisture).
So I soldered the defect contacts (be careful - you lost guarantee).
Now it works well.
Has anyone same problems? - May be, there are some more cold solder joints.
The assembly process of the PI seems to be not reliable.
Thanks - and have fun with the PI
Pi-xel
