- stevelloyd88
Install Mysql 5.7 on raspbian jesse - pi 3
I am trying to install Mysql 5.7 on my raspberri pi 3 running raspbian jesse. Has anyone does this before? Can you give me some pointers?
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: Install Mysql 5.7 on raspbian jesse - pi 3
sudo apt-get -y mariadb-server mariadb-client
That gets you Maria DB which is the more modern version of MySQL.
- stevelloyd88
Thanks, I was able to install it. however it seems that 10.0.27-MariaDB-0+deb8u1 (Raspbian) does not support "json" datatypes. I want mysql 5.7 for the json data type support.DougieLawson wrote:sudo apt-get -y mariadb-server mariadb-client
MySQL downloads, http://dev.mysql.com/downloads/mysql/#downloads, does not have an ARM version. There is the source code.
There is a change to the compile at 5.7.5. https://dev.mysql.com/doc/relnotes/mysq ... 5-7-5.html
- stevelloyd88
I finally got it! It took me several hours and about 8 attempts but I got it. Here are the steps I took.
Thanks to https://solarianprogrammer.com/2016/06/ ... -programs/ and a lot of trial and error.
- apt-get update
apt-get upgrade
vi //etc/apt/sources.list
change jesse to stretch
apt-get update
apt-get install gcc-6 g++-6
vi /etc/apt/sources.list
change stretch back to jesse
apt-get update
wget http://ftp.debian.org/debian/pool/main/ ... _armhf.deb
dpkg -i mysql-client-core-5.7_5.7.13-1~exp1_armhf.deb
apt-get update
apt-get install libaio1
apt-get install libaio-dev
dpkg -i mysql-client-5.7_5.7.13-1~exp1_armhf.deb
apt-get install mysql-common
dpkg -i mysql-server-core-5.7_5.7.13-1~exp1_armhf.deb
dpkg -i mysql-server-5.7_5.7.13-1~exp1_armhf.deb
apt-get install libmecab2
apt-get install libhtml-template-perl
apt-get upgrade
dpkg --help
dpkg --list
dpkg --list mysql
dpkg --help
dpkg --search mysql
dpkg --help
dpkg -r mysql-server-5.7
apt-get upgrade
dpkg -i libmecab2_0.996-3_armhf.deb
wget http://ftp.debian.org/debian/pool/main/ ... +1_all.deb
dpkg -i mysql-common_5.6.30-1~bpo8+1_all.deb
Thank you stevelloyd88 for your answer, today the version 5.7.13-1~exp1_armhf is no more on the debian pool
you should replace it by 5.7.15-1_armhf
Moreover, you should have to install liblz4-1 r127+
so, start with a
ps : the package libevent-core-2.0-5 is needed now for mysql-server
so, start with a
wget http://ftp.debian.org/debian/pool/main/l/lz4/liblz4-1_0.0~r131-2_armhf.deb
dpkg -i liblz4-1_0.0~r131-2_armhf.deb
You can get several versions of MySQL here: https://dev.mysql.com/downloads/repo/apt/ - Though I have not found any for arm yet...
I've boiled the above download list down to a fewer less command and update to current version 5.7.17-1:
wget http://ftp.debian.org/debian/pool/main/ ... .2_all.deb
sudo apt install libaio1 libaio-dev libhtml-template-perl libevent-core-2.0-5
sudo dpkg -i libmecab2_0.996-3_armhf.deb
sudo dpkg -i liblz4-1_0.0~r131-2+b1_armhf.deb
sudo dpkg -i mysql-common_5.8+1.0.2_all.deb
sudo dpkg -i mysql-client-core-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-client-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-server-core-5.7_5.7.17-1_armhf.deb
sudo dpkg -i mysql-server-5.7_5.7.17-1_armhf.deb
The links about don't work, I've browsed the 5.7 directorys and grabbed the armhf.debs doing the following;
However, I received the following errors;
I'm slightly burnt out today, so hopefully someone here can give me a nudge in the right direction?
(Originally I was trying to do master - master replication between rpi & ubuntu machines, only to realise after a week of configuring that 5.5 on the pi is not compatible, and the 5.5 install guide for ubuntu lead to dead ends, so now i'm trying to upgrade the pi)
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqlclient-dev_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqlclient20_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/libmysqld-dev_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-client-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-client-core-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-server-5.7_5.7.18-1+b1_armhf.deb
wget http://ftp.debian.org/debian/pool/main/m/mysql-5.7/mysql-server-core-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqlclient-dev_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqlclient20_5.7.18-1+b1_armhf.deb
sudo dpkg -i libmysqld-dev_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-client-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-client-core-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-server-5.7_5.7.18-1+b1_armhf.deb
sudo dpkg -i mysql-server-core-5.7_5.7.18-1+b1_armhf.deb
dpkg: dependency problems prevent configuration of mysql-client-core-5.7:
mysql-client-core-5.7 depends on liblz4-1 (>= 0.0~r130); however:
Version of liblz4-1:armhf on system is 0.0~r122-2.
mysql-client-core-5.7 depends on libstdc++6 (>= 5.2); however:
Version of libstdc++6:armhf on system is 4.9.2-10.
- DougieLawson
Raspbian Stretch includes MariaDB 10.1 which has everything in MySQL 5.7 plus a bunch more.
No there is no data type json support in that version of mariaDB, so there are things missing.DougieLawson wrote: ↑Fri Sep 15, 2017 4:12 pmRaspbian Stretch includes MariaDB 10.1 which has everything in MySQL 5.7 plus a bunch more.
10.2.7 is the first release with it.
- DougieLawson
That's because of DebIan's insane package policy. You won't get MariaDB 10.2 or later until DebIan Buster. If you need a more agile, more current package you'll have to switch to Mint, Ubuntu or Arch (which aren't as conservative as DebIan).c0ff3e wrote: ↑Sun Mar 04, 2018 5:28 pmNo there is no data type json support in that version of mariaDB, so there are things missing.DougieLawson wrote: ↑Fri Sep 15, 2017 4:12 pmRaspbian Stretch includes MariaDB 10.1 which has everything in MySQL 5.7 plus a bunch more.
MySQL 5.7 Docker Container for Raspberry Pi using Debian Sid
I successfully installed MySQL 5.7 into a Docker container and run it on Raspberry Pi 3. Details are in my blog post, see https://scito.ch/content/mysql-57-docke ... debian-sid
