link: https://www.amazon.com/Uniker-Raspberry ... B01LX526QA
show video: https://s3.amazonaws.com/rpi2/rpi+scree ... ENSHOW.mp4
There won't be many i/o left for other things.step 3. Config file to enable HD-TFT
Add the following line:Code: Select all
sudo nano /boot/config.txtCode: Select all
framebuffer_width=800 framebuffer_height=480 dtparam=spi=off dtparam=i2c_arm=off enable_dpi_lcd=1 display_default_lcd=1 dpi_output_format=0x6f015 dpi_group=2 dpi_mode=87 hdmi_timings=480 0 16 16 24 800 0 4 2 2 0 0 0 60 0 32000000 6 display_rotate=3
OK,thank u so much.I will try it.W. H. Heydt wrote:I have a very hard time believing the specs as presented. I've been working with 3.5" displays (Adafruit PiTFT and Neosec TinyLCD 35) and they have a resolution of 480x320. They're limited to about 20 fps due to the limitations of the SPI interface. To get higher resolutions and faster refresh rates, you need to go to an HDMI connection. The display you've linked to *appears* to be running off the GPIO connector, so the claims are...dubious, at least to me.
BMS Doug wrote:It isn't SPI based, it uses the GPIO DPI setup.
