I assume its D4, a double diode BAV99 that protects the broadcom's video output pin from becoming higher than 2.5Volt (The video DAC power supply voltage) or negative.
Burning this diode out can only mean that there have been dangerous voltage on the composite video cable. Perhaps your TV wasn't properly grounded, and the TV is leaking mains voltage to its low voltage internals, (or even its GND). Properly grounding the TV should help. If your TV doesn't have a ground pin on it power supply cable its probably a "double isolated device", which certainly shouldn't leak any dangerous voltages, which suggests its broken inside.
Alternatively its not the TV that is leaking the dangerous mains voltage, but it actually the PI's PSU that does it, and the TV is properly grounded, and acts as an exit path for the dangerous mains voltage on your PI.
Some very cheap chargers are actually dangerous, as this video shows.
http://www.youtube.com/watch?v=T88ej64aXUM&feature=plcp
safest thing to do is to replace D4 with another BAV99, after you have solved the problem, otherwise the next time more things may break than just D4.
