clytemnestra
Kernel panic
Fri Oct 07, 2016 9:37 pm
I tried following this guide http://www.waveshare.com/wiki/5inch_HDMI_LCD and combined with this one viewtopic.php?f=91&t=139917 for installing my 5'' screen.
I tried solving the problem like in this answer http://raspberrypi.stackexchange.com/qu ... block179-6
A reboot will say 'unknown block 179,2 instead of 6. And when I run
sudo fsck.ext4 -y /dev/mmcblk0p6
it says unknown sudo. I manage to log in as root, but this command won't work.
Most say it is a problem with updating, so shouldn't I have ran apt-get upgrade? Others say the SD card could be the problem, but it is a brand new 16GB one, so space shouldn't be an issue.
It ran Raspbian perfectly fine until I tried to install my screen's drivers.
I should've posted this in troubleshooting, if a moderator can move it, please.
clytemnestra
Re: Kernel panic
Fri Oct 07, 2016 11:32 pm
SOLVED IT!
So the problem was from the video driver, for some reason it was bugging it all no matter how many times I tried to reinstall Raspbian. I have no idea why this works, if someone can clarify, but instead of
root=/dev/mmcblk0p2
or
root=/dev/mmcblk0p6
I had to put
root=/dev/mmcblk0p7
I saw the 7th thing with
fdisk -l
but being a beginner have no idea what all this means.
Return to “Beginners”
