matthewh
Static Public IP on Rasbian Jessie Lite
Fri Oct 07, 2016 5:16 pm
I need to assign a static public IPv4 and IPv6 IP to the Ethernet interface of a Raspberry Pi running Rasbian Jessie Lite. So I need to assign a IP, subnet and gateway for both IPv4 and IPv6. How do I do that?
jstewa
Re: Static Public IP on Rasbian Jessie Lite
Fri Oct 07, 2016 5:34 pm
Add settings to the /etc/dhcpcd.conf file. You will need root access.
Go to the bottom of the file and add something like this:
interface eth0
static ip_address=192.168.x.xx/xx
static routers=192.168.1.xxx
static domain_name_servers= 8.8.8.8 8.8.4.4
Change the x's to whatever is appropriate for your situation.
Good luck.
Return to “Raspberry Pi OS”
