yotsclee
Set USB microphone as default capture device
Fri Oct 07, 2016 10:18 am
Hi, I am working on a project which requires voice recognition using Raspberry Pi 3. I would like to capture audio using USB microphone and use 3.5mm jack for playback. I can play and record sound using below code.
arecord -D hw:1,0 -r 16000 -f S16_LE test.wav
aplay ./test.wav
But I cannot make the USB microphone to be the default device. Anyone has any clue about it? Thanks in advance!
My ultimate goal is to get the voice recognition working. If anyone has any good tutorial, please enlighten me.
https://pypi.python.org/pypi/SpeechRecognition/
flatmax
Re: Set USB microphone as default capture device
Fri Oct 07, 2016 12:01 pm
Yep - you can create an asoundrc file which instructs alsa on which device to use as the default (using the default plugin).
pcm.!default {
	type hw
	card 0
ctl.!default {
	type hw
	card 0
Check here for more information :
http://www.alsa-project.org/main/index. ... ult_plugin
Discuss hearing, acoustics, audio injector products, - https://lists.audioinjector.net/mailman/listinfo/people
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
yotsclee
Sat Oct 08, 2016 6:29 am
Hi FlatMax:
I am sorry that I am new to Raspberry Pi and Linux. Would you please show me an example how to set 3.5mm jack as audio output and USB microphone as capture input? Thanks a lot for your help! I really appreciated it.
:D :D
flatmax
Sun Oct 09, 2016 4:35 am
I can try to help you, sure.
Can you show me the device names ? Type the following into a terminal (https://www.raspberrypi.org/documentati ... /terminal/) :
arecord -L
Karthik N N
Thu Mar 29, 2018 11:18 am
pcm.!default {
	type hw
	card 0
ctl.!default {
	type hw
	card 0
Even this did not work for me :? :( :( :( :(
please help
thanks in advance
Karthik N N
Thu Mar 29, 2018 4:56 pm
File "/home/pi/Nandas/stt.py", line 8, in <module>
audio=r.listen(source)
File "/usr/local/lib/python3.4/dist-packages/speech_recognition/__init__.py", line 652, in listen
buffer = source.stream.read(source.CHUNK)
File "/usr/local/lib/python3.4/dist-packages/speech_recognition/__init__.py", line 161, in read
return self.pyaudio_stream.read(size, exception_on_overflow=False)
File "/usr/local/lib/python3.4/dist-packages/pyaudio.py", line 608, in read
return pa.read_stream(self._stream, num_frames, exception_on_overflow)
KeyboardInterrupt
I am getting this error when executing
import speech_recognition as sr
#import urllib2
r=sr.Recognizer()
with sr.Microphone(device_index = 4, sample_rate = 48000) as source:
while True:
print("say")
print("Could notdjgh")
BING_KEY = "36fd56ca622648b2bdc19dfbfb922ef7" # Microsoft Bing Voice Recognition API keys 32-character lowercase hexadecimal strings
try:
print("I think you said " + r.recognize_bing(audio, key=BING_KEY))
except sr.UnknownValueError:
print("I could not understand audio")
except sr.RequestError as e:
print("Could not request results from Microsoft Bing Voice Recognition service; {0}".format(e))
Please Help
Thanks in advance
