I would like to use the Raspberry Pi 3B in combination with Raspbian for a commercial project.
It would be great if this thread could be used to collect all commands that are necessary to do this since there are already a lot of commercial projects out there and more are to be expected in the future.
If you find a mistake or can add a command that is missing here then it would be great if you could add this.
Ok, using forum search I found this:
Remove Wolfram
sudo apt-get -y --auto-remove purge wolfram-engine
sudo rm /usr/share/raspi-ui-overrides/application/wolfram-*
