josh_B
Cant connect raspberry pi to a laptop
Tue Oct 04, 2016 6:53 am
i've installed the latest image raspbian . and i wanted to connect it to the laptop ( not the router).
so , i enabled
network and sharing -> my wifi adapter - > properties - > turned on sharing.
connected raspberry pi to the laptop went to network and sharing went to "ethernet." and turned on radio button " obtain ip address automatically " .
now what should i type in the putty to get my raspberry pi connected ?
i tried :
1)ipconfig in cmd ...the ethernet port adrress which was :
ethernet adapter ethernet
autoconfiguration ip4 :169.254.193.83
it doesnt work
2)
i tried finding any ip's allocated to the adress in NMAP
cant find any ip assigned to raspberry pi.
please help
rpi model :2
os : raspbian jessie
jbudd
Re: Cant connect raspberry pi to a laptop
Tue Oct 04, 2016 7:46 am
It's not completely clear what you are trying to achieve.
That implies you want your laptop to act as the wireless access point and your Pi as the client.
That implies that you want your Pi to be the access point and your laptop to be the client.
The IP address 169.254.193.83 indicates that your laptop failed to find a DHCP server (to give it a real IP address). So, if your Pi is set up as an access point, and the laptop is connecting to it, you just need to change "Obtain an IP address automatically" to specifying an address in the same range as the Pi's.
As a matter of interest, if you have a router, why do you want to connect laptop and Pi directly?
Tue Oct 04, 2016 8:10 am
https://pihw.wordpress.com/guides/direc ... connection
You appear to not have Windows Connection Sharing set up correctly.
No changes should be required on the RPi unless you want Static IP.
