Wed Oct 12, 2016 12:01 pm
RaTTuS wrote:the micro usb sockets[where chosen because they can cope with 100's of thousands insertions,
if your power adapter one is slightly too big or you have been really rough with it it may fail
but the ones on the board should last a long time
+1 W.r.t. uUSB plugs & sockets in general - it's usually the
plug that "fails", to date** I've had two uUSB cable plugs "fail" to stay inserted in a uUSB socket (IIRC, one in a mobile phone, the other may have been in a Pi) but, once the cable was replaced everything continued to work fine. (IIRC, when I commented about this in an ancient post @jamesh also had experienced similar plug failure)
Trev.
**since early 2012
