jpiat
Switching between ap and host on pi3 wifi
Sun Oct 02, 2016 8:04 am
I'am trying to have my pi3 switch its WIFI between AP mode and host mode at the touch of a button. For this, i designed two script . The first script configures everything to AP mode :
#!/bin/bash
cp /etc/network/interfaces_hotspot /etc/network/interfaces
systemctl stop wpa_supplicant.service
ifdown wlan0
ifup wlan0
systemctl start hostapd.service
systemctl start dnsmasq.service
while the second switch the interface to host mode :
systemctl stop hostapd.service
systemctl stop dnsmasq.service
#systemctl disable hostapd.service
#systemctl disable dnsmasq.service
cp /etc/network/interfaces_local /etc/network/interfaces
ifdown wlan0
ip addr flush dev wlan0
pkill dhclient
pkill wpa_supplicant
ifup wlan0
The two script use preconfigured /et/network/interfaces configuration that works. The problem is that when i am in AP mode and switch to host mode, everything seems to work (wpa_supplicant is started), but it fails to connect to the AP. Sometime i just need to do a ifdown wlan0 and then ifup wlan0 but sometime i need to reboot the Pi.
Any idea on how to achieved the wanted behavior ?
ScheissSchiesser
Re: Switching between ap and host on pi3 wifi
Wed Mar 15, 2017 5:23 am
Did you ever end up getting this to work? I am trying to set this up as well.
Thanks!
