Raspberry Pi 3
OS: Raspbian, Jessie
SD card: Samsung EVO Plus 32G
Power Supply: 5v@2.4a
1) Cat 5 cable verified good, tested.
2) Router has been rebooted.
3) Another Pi 3 connects to router and receives dhcp leases.
4) Tested with 2 identical sd cards and fresh Raspbian installs.
From the time I first established ssh between the two RPi's, ip address has remained fixed on the same Pi 3. I know because I took notes. ip address has never changed. Can not get a lease from the router.
This issue is at board level not OS.
How do I release the default address?
