bubblegumpi
Can you run kerbal KSP on pi3?
Fri Sep 30, 2016 6:37 am
Has anyone tried this on a pi3? Is it fast enough? There is not much on the internet about it. Also when you download the KSP .zip for linux the files look like windows files. I must be missing something here
New to Linux, Keep in mind I'm legally blind, so my questions may seem dumb. Yes, I did a search, that's why I'm here. Links to FAQ'a and youtube are a HUGE help.| MY OS: Pi 3B with Oct'16 Noobs Raspberrian, 16Gb SD drive, HDMI video, no extras
RaTTuS
Contact: Twitter YouTube
Re: Can you run kerbal KSP on pi3?
Fri Sep 30, 2016 6:41 am
no
Covfefe
scotty101
Fri Sep 30, 2016 8:30 am
The KSP linux version has been compiled for running in "Intel compatible" x86 processors not ARM.
bubblegumpi
Thu Oct 06, 2016 1:59 am
scotty101 wrote:The KSP linux version has been compiled for running in "Intel compatible" x86 processors not ARM.
A bit more informative than the first post. Anyways is ARM the exception not the rule? Does this become a big problem when you are trying to use most "linux" programs? I bought the pi so I could have a Linux machine to learn and complement the PC. Or am I going to find out that there are alot of limitations due to the ARM architecture? One big thing is I want to use Software Defined Radio on it, but that doesn't do any good if most/everything is x86. :(
mikronauts
Thu Oct 06, 2016 2:01 am
I suggest you buy an x86 pc.
RaTTuS
Thu Oct 06, 2016 6:59 am
you asked a simple question - I provided the answer in the best way possible - if you wanted more info maybe the question could of been phrased better.
however
if you want to do 90% of what linux boxes do - i.e. the packages that are in the debian apt-get system then the RPi is fine -and will get you a long way down the road ,
if you want to run specialized programs from none authoritative sources then you will have difficulties [not that there is not a way for these things to work] YMMV
running a RPi is a great way of complimenting your x86 PC just be aware that it is not a machine that has the same power of most laptops / desktop you are likely to have
Covfefe
Thu Oct 06, 2016 7:05 am
bubblegumpi wrote:One big thing is I want to use Software Defined Radio on it, but that doesn't do any good if most/everything is x86. :(
http://www.rtl-sdr.com/tag/raspberry-pi
RPi 4B 4GB (SSD Boot)..
Return to “Gaming”
