bigdavethehorn
Is there a search facility within Raspbian?
Fri Aug 31, 2012 7:41 am
So, I'm looking for a particular .ini file on a fresh Raspbian Wheezy install, but I don't know where it is located. I found Raspbian's file manager and wandered about "My Computer" with no luck.
Is there a search function within Raspbian?
bredman
Re: Is there a search facility within Raspbian?
Fri Aug 31, 2012 8:01 am
To do this from the command line, if you need to find xxx.ini...
sudo find / -name "xxx.ini"
To get a list of all the .ini files in the system
sudo find / -name "*.ini" | less
Use the up/down arrows to move in the list, press q to quit.
This is not particular to Raspbian, it will work for any Linux distribution.
bob_binz
Fri Aug 31, 2012 9:27 am
An alternative (not sure of the most efficient option) is mlocate -
sudo apt-get install mlocate
Then run
sudo updatedb
(which I think is run regularly anyway, once installed.) Once updatedb has finished, use
locate <search-term>
i.e.
locate mylost.ini
bigdavethehorn
Fri Aug 31, 2012 10:56 am
Magic! Thanks to both of you!
Return to “Raspberry Pi OS”
