nautilus27
Syntax error in if code
Sat Sep 24, 2016 12:10 pm
Hey peeps,
Last year I made a hovercraft with Arduino and used skid steering via 2x motors. It worked great and controls were pretty accurate. So I'm trying to convert it to Python. I'm using Xbox 360 controller with xboxdrv drivers. Analog stick feedbacks are converted to certain values. Everything went smooth until i get syntax error for the if code:
  File "sample.py", line 55
    if left_y_1023 > 550
SyntaxError: invalid syntax
Why is this happening?
import xbox
import RPi.GPIO as GPIO
import time
def mymap(x, in_min, in_max, out_min, out_max):
    return int((x-in_min) * (out_max-out_min) / (in_max-in_min) + out_min)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(11,GPIO.OUT)
GPIO.setup(12,GPIO.OUT)
GPIO.setup(15,GPIO.OUT)
GPIO.setup(16,GPIO.OUT)
motor1 = GPIO.PWM(11,50)
motor2 = GPIO.PWM(12,50)
motor3 = GPIO.PWM(15,50)
motor4 = GPIO.PWM(16,50)
while not joy.Back():
    left_x_1023 = mymap(joy.leftX(),-1.0,1.0,0,1023)
    print(left_x_1023)," ",
    left_y_1023 = mymap(joy.leftY(),-1.0,1.0,0,1023)
    print(left_y_1023), " ",
    right_x_1023 = mymap(joy.rightX(),-1.0,1.0,0,1023)
    print(right_x_1023), " ",
    right_y_1023 = mymap(joy.rightY(),-1.0,1.0,0,1023)
    print(right_y_1023), " ",
    speed1 = mymap(left_y_1023, 550,1023,0,100)
    speed2 = mymap(left_y_1023, 500,0,0,100)
    turn1 = mymap(left_x_1023,500,0,-50,50)
    skid1a = (speed1 - turn1)
    skid1b = (speed1 + turn1)
    turn2 = mymap(left_x_1023,550,1023,-50,50)
    skid2a = (speed1 - turn2)
    skid2b = (speed1 + turn2)
    skid3a = (speed2 - turn1)
    skid3b = (speed2 + turn1)
    skid4a = (speed2 - turn2)
    skid4b = (speed2 + turn2)
    turn3 = mymap(left_x_1023,500,0,0,100)
    turn4 = mymap(left_x_1023,550,1023,0,100)
        if left_x_1023 > 501 and left_x_1023 < 549
            motor1.start(speed1)
            motor2.start(0)
            motor3.start(speed1)
            motor4.start(0)
joan
Re: Syntax error in if code
Sat Sep 24, 2016 12:14 pm
Python requires a colon at the start of a block.
See http://stackoverflow.com/questions/2155 ... -in-python
kusti8
You don't have a colon after the if statement
nautilus27
Sat Sep 24, 2016 12:16 pm
joan wrote:Python requires a colon at the end of the if statement.
Thanks! I'm such a Python noob really. I wish i knew a Python Language reference like Arduino Referance in Arduino website.
https://www.arduino.cc/en/Reference/HomePage
Is there any?
joan
Sat Sep 24, 2016 12:17 pm
Is there any?
Just search for a Python tutorial with Google. You should find one which chimes with you.
kusti8
Sat Sep 24, 2016 12:22 pm
Here's the documentation:
https://docs.python.org/3/
Return to “Python”
