ab1jx
Testing HDMI modes
Fri Sep 23, 2016 7:32 pm
I haven't actually tried this, just worked out the parts. In /boot create a file called prefix that contains everything you want in your config.txt except the HDMI mode, like
hdmi_group=2
hdmi_ignore_edid=0xa5000080
hdmi_force_hotplug=1
And create a script like this (in /boot) that's called on every boot (after a cd to /boot)
#!/bin/bash
declare -i mode=1
declare passes=n
if [ -e modefile ]; then mode=`cat modefile`; else mode=1; fi
echo -en "\007" # beep
# This times out in 5 seconds, logs y only if you hit y
read -t 5 -n 1 -p "Press y if mode worked " passes
echo
echo Logging: $mode $passes
echo $mode $passes >> logfile
# Set up for next boot
((mode++))
if [ $mode == 15 ] # mode 15 won't boot
then
((mode++));
fi
# modefile is mode storage through reboots
echo $mode > modefile
# Put everything up to hdmi_mode in a file called prefix
cp prefix config.txt
# Add the hdmi mode to the end
echo "hdmi_mode="$mode >> config.txt
while [[ $mode -lt 87 ]]
do
# uncomment to actually reboot
#reboot
exit
done
Uncomment the reboot to have it actually reboot the machine.
Logfile will look like this after it's done:
1 y
2 n
3 y
4 y
5 n
If you don't see the mode working, don't hit y and it will time out after 5 seconds and not get a y in the log file for that mode.
ab1jx
Re: Testing HDMI modes
Sat Sep 24, 2016 2:29 am
OK, so it's not perfect but it's better than nothing. I added tvservice -s to it at the last minute, but it occurred to me there's no return to a known good mode at the end. I let it run for an hour and I could see things changing for a while but then they stopped. Occasionally the warning that the input signal was out of range appeared on the monitor. I saw lots of modes that worked. Mode 57 was what I was using when I started.
But I installed the script the Debian way as a service I guess (update-rc.d) and it ran with no beep when booted or prompt. After an hour I pulled the power plug and stuck the SD card in a reader in another machine to see what happened.
It seemed to stop at mode 73, which might be timing coincidence or maybe that mode wouldn't boot. Obviously I need to call the script at boot a different way. But you can see some modes like 34 where tvservice reports a different mode than what I was trying to use. Ones that were really bad revert to mode 16, which I can't get to work anyway. I kept hitting Y whenever I saw working video hoping they might end up buffered and get through, but none did. Now I have a few hoops to jump through to get my SD card back to normal. I do have a recent clone of it. Got it, no harm done.
state 0x12000a [HDMI DMT (57) RGB full 16:10], 1680x1050 @ 60.00Hz, progressive
2
state 0x120006 [DVI DMT (2) RGB full 16:10], 640x400 @ 85.00Hz, progressive
3
state 0x120006 [DVI DMT (3) RGB full unknown AR], 720x400 @ 85.00Hz, progressive
4
state 0x120006 [DVI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
5
state 0x120006 [DVI DMT (5) RGB full 4:3], 640x480 @ 72.00Hz, progressive
6
state 0x120006 [DVI DMT (6) RGB full 4:3], 640x480 @ 75.00Hz, progressive
7
state 0x120006 [DVI DMT (7) RGB full 4:3], 640x480 @ 85.00Hz, progressive
8
state 0x120006 [DVI DMT (8) RGB full 4:3], 800x600 @ 56.00Hz, progressive
9
state 0x120006 [DVI DMT (9) RGB full 4:3], 800x600 @ 60.00Hz, progressive
10
state 0x120006 [DVI DMT (10) RGB full 4:3], 800x600 @ 72.00Hz, progressive
11
state 0x120006 [DVI DMT (11) RGB full 4:3], 800x600 @ 75.00Hz, progressive
12
state 0x120006 [DVI DMT (12) RGB full 4:3], 800x600 @ 85.00Hz, progressive
13
state 0x120006 [DVI DMT (13) RGB full 4:3], 800x600 @ 120.00Hz, progressive
14
state 0x120006 [DVI DMT (14) RGB full 16:9], 848x480 @ 60.00Hz, progressive
16
state 0x120006 [DVI DMT (16) RGB full 4:3], 1024x768 @ 60.00Hz, progressive
17
state 0x120006 [DVI DMT (17) RGB full 4:3], 1024x768 @ 70.00Hz, progressive
18
state 0x120006 [DVI DMT (18) RGB full 4:3], 1024x768 @ 75.00Hz, progressive
19
state 0x120006 [DVI DMT (19) RGB full 4:3], 1024x768 @ 85.00Hz, progressive
20
state 0x120006 [DVI DMT (20) RGB full 4:3], 1024x768 @ 120.00Hz, progressive
21
state 0x120006 [DVI DMT (21) RGB full 4:3], 1152x864 @ 75.00Hz, progressive
22
state 0x120006 [DVI DMT (22) RGB full 15:9], 1280x768 @ 60.00Hz, progressive
23
state 0x120006 [DVI DMT (23) RGB full 15:9], 1280x768 @ 60.00Hz, progressive
24
state 0x120006 [DVI DMT (24) RGB full 15:9], 1280x768 @ 75.00Hz, progressive
25
state 0x120006 [DVI DMT (25) RGB full 15:9], 1280x768 @ 85.00Hz, progressive
26
state 0x120006 [DVI DMT (26) RGB full 15:9], 1280x768 @ 120.00Hz, progressive
27
state 0x120006 [DVI DMT (27) RGB full 16:10], 1280x800 @ 60.00Hz, progressive
28
state 0x120006 [DVI DMT (28) RGB full 16:10], 1280x800 @ 60.00Hz, progressive
29
state 0x120006 [DVI DMT (29) RGB full 16:10], 1280x800 @ 75.00Hz, progressive
30
state 0x120006 [DVI DMT (30) RGB full 16:10], 1280x800 @ 85.00Hz, progressive
31
state 0x120006 [DVI DMT (31) RGB full 16:10], 1280x800 @ 120.00Hz, progressive
32
state 0x120006 [DVI DMT (32) RGB full 4:3], 1280x960 @ 60.00Hz, progressive
33
state 0x120006 [DVI DMT (33) RGB full 4:3], 1280x960 @ 85.00Hz, progressive
34
state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
35
state 0x120006 [DVI DMT (35) RGB full 5:4], 1280x1024 @ 60.00Hz, progressive
36
state 0x120006 [DVI DMT (36) RGB full 5:4], 1280x1024 @ 75.00Hz, progressive
37
state 0x120006 [DVI DMT (37) RGB full 5:4], 1280x1024 @ 85.00Hz, progressive
38
39
state 0x120006 [DVI DMT (39) RGB full 16:9], 1360x768 @ 60.00Hz, progressive
40
state 0x120006 [DVI DMT (40) RGB full 16:9], 1360x768 @ 120.00Hz, progressive
41
state 0x120006 [DVI DMT (41) RGB full 4:3], 1400x1050 @ 60.00Hz, progressive
42
state 0x120006 [DVI DMT (42) RGB full 4:3], 1400x1050 @ 60.00Hz, progressive
43
state 0x120006 [DVI DMT (43) RGB full 4:3], 1400x1050 @ 75.00Hz, progressive
44
45
46
state 0x120006 [DVI DMT (46) RGB full 16:10], 1440x900 @ 60.00Hz, progressive
47
state 0x120006 [DVI DMT (47) RGB full 16:10], 1440x900 @ 60.00Hz, progressive
48
state 0x120006 [DVI DMT (48) RGB full 16:10], 1440x900 @ 75.00Hz, progressive
49
state 0x120006 [DVI DMT (49) RGB full 16:10], 1440x900 @ 85.00Hz, progressive
50
51
state 0x120006 [DVI DMT (51) RGB full 4:3], 1600x1200 @ 60.00Hz, progressive
52
53
54
55
56
57
state 0x120006 [DVI DMT (57) RGB full 16:10], 1680x1050 @ 60.00Hz, progressive
58
state 0x120006 [DVI DMT (58) RGB full 16:10], 1680x1050 @ 60.00Hz, progressive
59
60
61
62
63
64
65
66
67
68
state 0x120006 [DVI DMT (68) RGB full 16:10], 1920x1200 @ 60.00Hz, progressive
69
70
71
72
The version I ran:
#!/bin/bash
cd /boot
declare -i mode=1
declare passes=n
echo
tvservice -s >> logfile
((mode++))
# Skip over mode 15, won't boot
if [ $mode == 15 ]
then
  ((mode++));
fi
do
reboot
#echo "reboot here"
exit
done
ab1jx
Sat Sep 24, 2016 2:38 pm
The same monitor, xrandr on an OpenBSD machine connected to the DVI input shows
xrandr program version 1.4.3
Screen 0: minimum 640 x 400, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
1920x1080 60.00*
1400x1050 75.00 60.00
1280x1024 75.00 60.00
1280x960 60.00
1152x864 75.00
1024x768 75.00 60.00 70.00
832x624 75.00
800x600 75.00 60.00 72.00 56.00
640x480 75.00 60.00 73.00
720x400 70.00
I switch to the HDMI input where the Pi is and run xrandr:
Screen 0: minimum 1680 x 1050, current 1680 x 1050, maximum 1680 x 1050
default connected 1680x1050+0+0 (0x1d9) normal (normal) 0mm x 0mm
Identifier: 0x1d8
Timestamp: 38299548
Subpixel: unknown
Clones:
CRTC: 0
CRTCs: 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
1680x1050 (0x1d9) 0.000MHz *current
h: width 1680 start 0 end 0 total 1680 skew 0 clock 0.00KHz
v: height 1050 start 0 end 0 total 1050 clock 0.00Hz
The only mode the Pi sees isn't among the modes OpenBSD sees. All I want is to do the monitor's native 1920x1080 with the Pi. The timing is different or something. Oh, of course, the timing is set by the hdmi_* numbers in config.txt but I can't find a 1920x1080 that works.
I haven't looked at the framebuffer size, hmm.
ab1jx
Fri Sep 30, 2016 2:37 pm
OK, the real final version which mostly works correctly. It continues on past mode 86, but just ctrl-c it to stop it. The first mode isn't logged correctly because modefile has a 1 in it and the current HDMI mode is whatever your previous config.txt says, after the first reboot it's OK.
This version runs as the pi user, so make a dir /home/pi/hdmimodes. With raspi-config or the GUI version set the machine to autologin the pi user to a command line. At the end of pi's .bashrc add the line
/home/pi/hdmimodes/trymodes
Inside /home/pi/hdmimodes create modefile with the digit 1 in it (possibly optional). Create a file called prefix which contains
hdmi_group=2
Create the actual script file trymodes which contains
#!/bin/bash
# This version lives in /home/pi/hdmimodes not /boot
declare -i mode=1
declare passes=n  # Whether mode passed
# Change this to a working mode if you know one
# 57 on my Dell monitor, 35 on my Sony
declare -i good_mode=35
if [ -e /home/pi/hdmimodes/modefile ]; then mode=`cat /home/pi/hdmimodes/modefile`; else mode=1; fi
echo
echo $mode $passes >> /home/pi/hdmimodes/logfile
tvservice -s >> /home/pi/hdmimodes/logfile
date >> /home/pi/hdmimodes/logfile
((mode++))
if [ $mode == 15 ]
then
  ((mode++));
fi
echo $mode > /home/pi/hdmimodes/modefile
cp /home/pi/hdmimodes/prefix /home/pi/hdmimodes/config.txt
echo "hdmi_mode="$mode >> /home/pi/hdmimodes/config.txt
sudo cp /home/pi/hdmimodes/config.txt /boot/config.txt
do
sleep 1  # to allow seeing any error messages
reboot
exit 0
done
# After loop:
# The last mode may not have worked so restore video.
# There should be a return to a known good mode here, like 57
# I use 57 downstairs, 35 upstairs
# Change for your situation or use hdmi_safe=1
echo "hdmi_mode="$good_mode >> /home/pi/hdmimodes/config.txt
reboot  # one last time
exit 0
chmod trymodes to executable like
chmod +x trymodes
and be sure the pi user owns the directory and the files inside.
Find a free hour or so and reboot to start it. Hit Y if the mode worked, I used N or ? for modes that mostly worked and maybe could have been corrected using the monitor controls. It's just a character that gets logged, it's for your own reference. You could rate them 1 to 5. Don't hit anything if you can't read the screen. About 1995 there used to be a DOS program that essentially did what this does, but in that situation a program could change video modes, here the GPU sets the modes on boot and requires reboots to change them.
My logfile looked like
1 y
Thu Sep 29 13:30:20 EDT 2016
2 y
Thu Sep 29 13:30:46 EDT 2016
3
Thu Sep 29 13:31:27 EDT 2016
4 y
Thu Sep 29 13:31:52 EDT 2016
5 y
Thu Sep 29 13:33:13 EDT 2016
6 y
Thu Sep 29 13:33:34 EDT 2016
7 y
Thu Sep 29 13:34:20 EDT 2016
8 y
Thu Sep 29 13:34:46 EDT 2016
9 y
Thu Sep 29 13:35:15 EDT 2016
10 y
Thu Sep 29 13:35:45 EDT 2016
11 y
Thu Sep 29 13:36:15 EDT 2016
12 y
Thu Sep 29 13:36:46 EDT 2016
13
Thu Sep 29 13:37:25 EDT 2016
14 y
Thu Sep 29 13:37:51 EDT 2016
16 y
Thu Sep 29 13:38:18 EDT 2016
17 y
Thu Sep 29 13:38:35 EDT 2016
18 y
Thu Sep 29 13:39:09 EDT 2016
19 y
Thu Sep 29 13:39:36 EDT 2016
20
Thu Sep 29 13:40:23 EDT 2016
21 y
Thu Sep 29 13:40:42 EDT 2016
22
Thu Sep 29 13:41:24 EDT 2016
23 y
Thu Sep 29 13:41:46 EDT 2016
24 y
Thu Sep 29 13:42:16 EDT 2016
25 y
Thu Sep 29 13:42:34 EDT 2016
26
Thu Sep 29 13:43:24 EDT 2016
27
Thu Sep 29 13:44:41 EDT 2016
28
Thu Sep 29 13:45:23 EDT 2016
29 y
Thu Sep 29 13:45:41 EDT 2016
30
Thu Sep 29 13:46:24 EDT 2016
31
Thu Sep 29 13:46:54 EDT 2016
32 y
Thu Sep 29 13:47:20 EDT 2016
33 y
Thu Sep 29 13:47:47 EDT 2016
34
Thu Sep 29 13:48:26 EDT 2016
35 y
Thu Sep 29 13:48:49 EDT 2016
36 y
Thu Sep 29 13:49:18 EDT 2016
37 y
Thu Sep 29 13:49:43 EDT 2016
38
Thu Sep 29 13:50:22 EDT 2016
39 y
Thu Sep 29 13:50:44 EDT 2016
40
Thu Sep 29 13:51:26 EDT 2016
41
Thu Sep 29 13:51:57 EDT 2016
42 y
Thu Sep 29 13:52:27 EDT 2016
43 y
Thu Sep 29 13:53:41 EDT 2016
44
Thu Sep 29 13:54:23 EDT 2016
45
Thu Sep 29 13:54:53 EDT 2016
46 ?
Thu Sep 29 13:55:15 EDT 2016
47 ?
Thu Sep 29 13:55:53 EDT 2016
48 ?
Thu Sep 29 13:56:13 EDT 2016
49 ?
Thu Sep 29 13:56:42 EDT 2016
50 n
Thu Sep 29 13:57:18 EDT 2016
51
Thu Sep 29 13:57:50 EDT 2016
52 n
Thu Sep 29 13:58:07 EDT 2016
53 n
Thu Sep 29 13:58:39 EDT 2016
54
Thu Sep 29 13:59:21 EDT 2016
55
Thu Sep 29 13:59:51 EDT 2016
56 n
Thu Sep 29 14:00:23 EDT 2016
57 n
Thu Sep 29 14:00:41 EDT 2016
58
Thu Sep 29 14:01:22 EDT 2016
59 n
Thu Sep 29 14:01:39 EDT 2016
60
Thu Sep 29 14:02:21 EDT 2016
61
Thu Sep 29 14:02:52 EDT 2016
62 n
Thu Sep 29 14:03:13 EDT 2016
63
Thu Sep 29 14:03:52 EDT 2016
64
Thu Sep 29 14:04:24 EDT 2016
65
Thu Sep 29 14:04:57 EDT 2016
66
Thu Sep 29 14:05:28 EDT 2016
67
Thu Sep 29 14:06:00 EDT 2016
68
Thu Sep 29 14:06:26 EDT 2016
69 n
Thu Sep 29 14:06:57 EDT 2016
70 n
Thu Sep 29 14:07:22 EDT 2016
71 n
Thu Sep 29 14:07:50 EDT 2016
72 n
Thu Sep 29 14:08:26 EDT 2016
73
Thu Sep 29 14:09:01 EDT 2016
74
Thu Sep 29 14:09:33 EDT 2016
75 n
Thu Sep 29 14:09:53 EDT 2016
76 n
Thu Sep 29 14:10:14 EDT 2016
77 n
Thu Sep 29 14:10:51 EDT 2016
78 n
Thu Sep 29 14:11:22 EDT 2016
79 n
Thu Sep 29 14:11:49 EDT 2016
80 n
Thu Sep 29 14:12:17 EDT 2016
81 y
state 0x120006 [DVI DMT (81) RGB full 16:9], 1366x768 @ 60.00Hz, progressive
Thu Sep 29 14:12:44 EDT 2016
82
state 0x120006 [DVI DMT (82) RGB full 16:9], 1920x1080 @ 60.00Hz, progressive
Thu Sep 29 14:13:27 EDT 2016
83 n
state 0x120006 [DVI DMT (83) RGB full 16:9], 1600x900 @ 60.00Hz, progressive
Thu Sep 29 14:13:46 EDT 2016
84
state 0x120006 [DVI DMT (84) RGB full 16:9], 2048x1152 @ 60.00Hz, progressive
Thu Sep 29 14:14:27 EDT 2016
85 y
state 0x120006 [DVI DMT (85) RGB full 16:9], 1280x720 @ 60.00Hz, progressive
Thu Sep 29 14:14:49 EDT 2016
86 n
state 0x120006 [DVI DMT (86) RGB full 16:9], 1366x768 @ 60.00Hz, progressive
Thu Sep 29 14:15:18 EDT 2016
87 y
Thu Sep 29 14:15:52 EDT 2016
88 y
Thu Sep 29 14:16:17 EDT 2016
89 y
Thu Sep 29 14:16:48 EDT 2016
90 y
Thu Sep 29 14:17:28 EDT 2016
91 y
Thu Sep 29 14:17:46 EDT 2016
Take the /home/pi/hdmimodes/trymodes line out of pi's .bashrc when you're done and turn off autologin with raspi-config. You can use ctrl-alt-F2 to log in at a normal tty once you've done ctrl-C at a prompt to stop the script, it sort of monopolizes tty1.
nostromopi
Wed Dec 28, 2016 5:25 pm
This script is most interesting!!
I noticed i could get almost "pixel perfect" using these HDMI_CVT= in the config.txt under the retropie's /boot but is there no way i can have a game run in a specific mode and when another game is launched that requires a different mode to automatically switch to it??
It would be such a shame as the retro pie is capable of going 1:1 with the games in native resolution.
A fes i have tested on my Sony PVM are:
hdmi_cvt=320 262 60 1 (all neo geo run great with this)
hdmi_cvt=384 262 60 1 (ghouls and ghost arcade runs perfect with this as it near native res)
hdm_cvt=256 262 60 1 (black tiger arcade and chukka arisen arcade near perfect)
If only i could configure a game-specific something that tells the pi to use these modes..
ab1jx
Wed Dec 28, 2016 5:54 pm
The only way I've seen to switch video modes involves rebooting, since as I understand it, the GPU boots first then it boots the CPU. My script rewrites config.txt so on the next boot it comes up in a different mode. It seems conceivable that some tool could directly manipulate the GPU but I don't know of one. Whether this would be worthwhile for just playing games I don't know. I don't play them.
You could always pick up some cheap SD cards and set one up for each different video mode and only put those games on it. I have some of these and they seem OK, there are different sizes. I'd stick with class 10 http://www.gearbest.com/memory-cards/pp_350764.html $6 each
Wed Dec 28, 2016 6:47 pm
ab1jx wrote:The only way I've seen to switch video modes involves rebooting, since as I understand it, the GPU boots first then it boots the CPU.
You can switch video modes using the tvservice command.
[email protected]:/usr/sbin $ tvservice -h
Usage: tvservice [OPTION]...
  -p, --preferred                   Power on HDMI with preferred settings
  -e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
                                      MODE (see --modes) and DRIVE (HDMI, DVI)
  -t, --ntsc                        Use NTSC frequency for HDMI mode (e.g. 59.94Hz rather than 60Hz)
  -c, --sdtvon="MODE ASPECT"        Power on SDTV with MODE (PAL or NTSC) and ASPECT (4:3 14:9 or 16:9)
  -o, --off                         Power off the display
  -m, --modes=GROUP                 Get supported modes for GROUP (CEA, DMT)
  -M, --monitor                     Monitor HDMI events
  -s, --status                      Get HDMI status
  -a, --audio                       Get supported audio information
  -d, --dumpedid <filename>         Dump EDID information to file
  -j, --json                        Use JSON format for --modes output
  -n, --name                        Print the device ID from EDID
  -h, --help                        Print this information
You will also need to refresh the framebuffer using fbset, and maybe redraw the GUI using xrefresh if you use a GUI.
nostromopi
Wed Dec 28, 2016 7:57 pm
I feel we are on to something here
So tvservice,framebufferset..could it be possible to pass these arguments along with the start of a game so that these would be executed before the game and thus allow the game to run with the changed resolution?
If this would be possible..man..that would terrific!
ab1jx
Wed Dec 28, 2016 7:59 pm
But how do you use cvt modes with tvservice?
