Assuming there is someone working on omxplayer somewhere may I make some suggestions for development:
1. On quit (part way through playing something) output a value that represents the position in the file (byte count, seconds, minutes, anything).
2. Add a command line option (which takes above position value) to allow play to be resumed from where you left off.
3. Occasionally output a progress value (perhaps the same file position and file length) so a controlling program can present a progress bar.
4. Perhaps allow a position value to be entered while playing, and seek to that position.
I am not a c++ developer (I use Java) and haven't the first idea about getting involved in Git but I could probably some of hack these changes for myself, given enough time but it would be nice if they were available to everyone I think.
Re: omxplayer development
All the things that you have written works on XBMC. Becouse XBMC uses omxplayer, I suppose that it is already patched or it includes all features you asked.
- Raspberry Pi Engineer & Forum Moderator
Well, that's how open source works. The features you suggest sound straightforward to implement and could be useful - have a go.Howard wrote:I am not a c++ developer (I use Java) and haven't the first idea about getting involved in Git but I could probably some of hack these changes for myself, given enough time but it would be nice if they were available to everyone I think.
The git side is worth learning about. Create a guthub account. Clone the omxplayer repository. Make the changes to your repository. If they are good, press "pull request", and they can be fed back into the main code.
