hyndrix
Switching between known Wifi networks
Thu Sep 22, 2016 10:54 am
I already posted this on stackoverflow but without success:
I want to switch between known Wifi networks using the terminal/shell scripts without manual intervention. The Wifi networks are registered using the built-in Raspbian Wifi managing tool.
The wicd-cli tool (apt-get install wicd-cli) seems to be perfect for this:
wicd-cli --wireless -c "myssid" "mypassword"
The command executes successfully with a Done! message but the current Wifi connection is disconnected and the new one to myssid is not built up.
I also tried to connman tool but it completely breaks Wifi until the tool is uninstalled.
How can I switch between Wifi networks?
Regards,
lmarmisa
Re: Switching between known Wifi networks
Sat Sep 24, 2016 10:15 am
I recommend this procedure.
Define two (or more) wifi profiles for different wifi networks. I will store those profile files in the directory /etc/wpa_supplicant. For example:
File /etc/wpa_supplicant/wifi1
country=ES (use your country code here!)
update_config=1
network={
	ssid="SSID_WIFI1_HERE"
	psk="passphrasewifi1here"
File /etc/wpa_supplicant/wifi2
update_config=1
network={
	ssid="SSID_WIFI2_HERE"
	psk="passphrasewifi2here"
Then you have to create a script for switching between networks:
nano switchwifi
#!/bin/bash
cp /etc/wpa_supplicant/$1 /etc/wpa_supplicant/wpa_supplicant.conf
dhclient -r wlan0
ifdown wlan0
ifup wlan0
dhclient -v wlan0
echo
iwconfig wlan0
ifconfig wlan0
Give exec permission to your script file:
chmod +x switchwifi
The script must be run with root privileges:
sudo ./switchwifi wifi1
sudo ./switchwifi wifi2
Return to “Advanced users”
