hello_goio
Ivan – a mutipurpose plastic case combines sensors with Pi 3
Thu Sep 22, 2016 6:44 am
Hello Everyone,
We found this cases section of the Raspberry Pi forum and would like to introduce you to Ivan, our new multi-purpose, configurable plastic enclosure with internal mounting points for hardware platforms such as Raspberry Pi-3 and mounting plates for various sensors such as a camera and a movement detector.
Ivan also incorporates a PCB populated with 10 front panel push button switches configured as 4 intuitive up/down and left/right functionality and 6 additional switches. Ivan also incorporates two multi-coloured RGB LED’s. Users connect LED's and switches to their chosen hardware platform using their own hook-up cables.
Ivan additionally incorporates:
Removable rear panel providing screw-less access to user’s choice of electronic platform.
A battery cavity to accommodate a 2000 mAh Li-Po battery.
Adjustable tilt/swivel bench-top or wall mount base.
Removable side panel specific to: Raspberry Pi models 3, 2 and B+
Another removable side panel specific to: Raspberry Pi Zero.
Yet another side panel which is blank, enabling users to customise holes as user requires.
Removable open frame base panel suited to Raspberry Pi models 3, 2 and B+ et al.
Another removable blank base panel enabling users to customise holes as required.
Internal ring mount to glue a user supplied speaker. We designed a speaker grill in the front surface plastic.
Internal ring mount to glue a user supplied microphone. User is required to make a hole through Ivan if they choose to fit this.
Supporting the Dev community
To support the developer community, we intend to release the STL files of a generic hardware mounting plate, a generic side panel and a blank base panel enabling developers to 3D print their own mounting plates and panels customised to their needs.
Find Ivan on Indiegogo or us at goio.co
Paul Webster
Contact: Twitter
Re: Ivan – a mutipurpose plastic case combines sensors with
Thu Sep 22, 2016 9:42 am
Looks like a clever design and the prices on indiegogo seem good (not checked shipping costs though).
