Hi all, i'm all new to this raspberry pi business.. but enjoying messing about with it so far.
However..
I've got a raspberry pi zero & am using an HDMI to VGA converter to connect it to an old vga monitor.
This Converter has an Audio out 3.5mm jack on it, so I assumed I could connect this to a amplified speaker to output the sound from retropie.
This doesn't seem to be the case.
Does anyone know if this is actually possible? I had to change several settings in the config file for the vga monitor to actually get the video output, so I'm wondering whether by doing this it disables the audio that would otherwise work when using HDMI, as we're forcing it to do something else (vga through hdmi)
(when I connected to pi to an hdmi tv the video & sound work fine)
I hope that make sense!... cheers guys
