occupied
Relays and Voltage
Sun Sep 18, 2016 9:56 pm
Hello all,
Something I should know the answer to but alas I don't.
I have some relays:
My plan was to run 5V to VCC, GND to GND and 3.3V GPIO to IN... but no dice :(
I then connected 3.3V to VCC and the relay works great :)
So what is the reason the latter worked while the former wouldn't?
Any tips appreciated!
alexeames
Re: Relays and Voltage
Sun Sep 18, 2016 10:18 pm
You'll probably find they trigger when connected to GND and are OFF when connected to 3V3.
These kinds of relays are most often HIGH = OFF and LOW = ON. It can be confusing if you don't know :D
Alex Eames RasPi.TV, RasP.iO
occupied
Mon Sep 19, 2016 11:04 pm
Thanks for the tip! :)
