scooter800m
led indicators
Fri Sep 16, 2016 6:19 pm
i did all of this with windows remote desktop and the xrdp server using a pi 3.
i was running a python script through teminal (with the desktop going) on my pi that had been running for nearly 24 hours, and i decided to start minecraft pi, i let my pi sit for a few minutes to get minecraft pi going, i came back to it and found my connection had frozen and then get a message saying the connection was stopped, i tried using my SSH terminal PuTTy to see if i could reboot it, and it wouldn't connect, i looked at my pi and the led's were as follows:
- power was a solid red
- activity was a solid yellow
what does this mean?
drgeoff
Re: led indicators
Sat Sep 17, 2016 7:33 am
The power LED should always be solid red. That indicates that the PSU is connected and supplying adequate power.
The activity LED is the equivalent of the Hard Disk LED on a PC or laptop. It indicates that the SD card is being read or written.
Both of the above have some degree of software drive to them. It is possible that if the RPi has crashed they may be frozen and no longer telling the truth.
Quis custodiet ipsos custodes?
scooter800m
Re: led indicators
Tue Sep 20, 2016 11:43 pm
interesting that you say that about the power led, cause after raspbian gets booting the power led turns off. thanks though.
Douglas6
Re: led indicators
Wed Sep 21, 2016 12:07 am
scooter800m wrote:after raspbian gets booting the power led turns off.
That's abnormal behavior. It could well indicate a low-voltage condition, which can easily cause other instabilities. I would use a better power supply and/or power USB cable.
scooter800m
Re: led indicators
Wed Sep 21, 2016 5:29 pm
i am using a samsung wall adapter that outputs 5v 2.0 amp, it is the best that i can do with a usb power, i can't find any adapters that will output more than that on 5v. and when i have a screen attached to my pi the video singal regularly quits out and then comes back after a few seconds, i can scource that to low power, although my pi is the only one that seems to do this on 5v 2.0 amp, all the youtube vids that i see people messing around on other pi 3's their screen is perfectly fine, and their using 5v 2.0 amp.
what might be causing this case specific problem? i run in headless mode over ethernet just to keep power consumption to a minimum.
Douglas6
Re: led indicators
Wed Sep 21, 2016 5:38 pm
If the power supply is actually capable of 2A at 5v, the next thing to check is the cable between the supply and the Pi. Cheaper cables use Christmas tinsel instead of copper wires, which can significantly drop the voltage. I like to use 5v2 supplies, but a good cable should work (the shorter, the better), again assuming the supply is not lying about its specs.
W. H. Heydt
Re: led indicators
Wed Sep 21, 2016 6:45 pm
scooter800m wrote:i am using a samsung wall adapter that outputs 5v 2.0 amp, it is the best that i can do with a usb power, i can't find any adapters that will output more than that on 5v. and when i have a screen attached to my pi the video singal regularly quits out and then comes back after a few seconds, i can scource that to low power, although my pi is the only one that seems to do this on 5v 2.0 amp, all the youtube vids that i see people messing around on other pi 3's their screen is perfectly fine, and their using 5v 2.0 amp.
You don't say where you live...
In the US: http://www.mcmelectronics.com/product/28-19336
in the UK (with international plug set): http://uk.rs-online.com/web/p/plug-in-p ... y/9098135/
Either of those with keep a Pi3B very happy as regards power.
scooter800m
Re: led indicators
Tue Sep 27, 2016 1:46 pm
thanks
Return to “Off topic discussion”
