jeffzumwalt32 wrote:First time here and new to the Pi world. I have updated my pi 3, just wanted to put that out there. I have installed apache2 and php5 libapache2. My issue is when i try to delete the old index.html file using sudo rm index.html I get a return of rm: connot remove 'index.html': no such file or directory.
It's probably best to use
ls
to see what is in a directory before trying to delete things. It might be that the file is really called
index.htm
in which case you'll get the error and it will still be there potentially interfering with whatever you were worried about.
