Have this very troubling issue for the last couple of days. Spent many hours trying to figure this out.
It's my first PITS project, so maybe I am missing something basic.
-- The Stdout Log is here - https://www.dropbox.com/s/huwjwus9fq0je ... g.txt?dl=0
(failed to upload a file)
-- PITS fails to operate - RTTY and APRS.
-- I see a carrier in the 434.250 frequency but no side bands transmission.
-- Nothing on the 144.8 band
The most troubling thing, is that whenever I manually start the Tracker, I see that it completely ignores the Pisky.txt file.
-- It doesn't set the payload name
-- doesn't change frequency
Attaching a dump of the StdOutput. You can can see it seems only GPS is working in a loop.
Troubleshooting so far :
- re-installed the RPI
- re assembled the sub-boards
- checked the battery voltages
- Checked the receiver with a HabDuino board - seems to transmit fine.
- I ran some "printf" breakpoints in the tracker code.
- Until recently I used the RPI PDF manual.
- As I was troubleshooting, I found out the web page with the additional step of the serial port. - suggest to update the PDF asap.
Any help ?
thanks
