BLL
Using rpi-clone - problems
Fri Sep 09, 2016 11:14 am
Hi
I am experimenting with rpi-clone on my RasPi model 3 with jessie. It fails every time!
Here is what I do:
1) Put 16GB SD card, formatted all ext4, into USB card reader attached to the Pi.
2) Check with sudo fdisk -l that it shows. It shows as sdb1.
3) Run sudo rpi-clone sdb1 and I get:
======== Clone Summary ========
Clone mode : rsync modified files to existing sdb1 file systems
Clone destination disk : sdb1
Clone destination rootfs : /dev/sdb12 (no label) on /mnt/clone
Clone destination bootfs : /dev/sdb11 on /mnt/clone/boot
Verbose mode : off
Final check, is it Ok to proceed with the clone (yes/no)?: y
=> Mounting /dev/sdb12 (no label) on /mnt/clone
mount: special device /dev/sdb12 does not exist
Mount failure of /dev/sdb12, aborting!
I have checked that /mnt/clone and mnt/clone/boot exist
Where is this sdb12 coming from? All fdisk shows is sdb1
Any help most welcome!
Brian
nl3prc
Re: Using rpi-clone - problems
Fri Sep 09, 2016 11:21 am
check with df -h if your entering the writh drive
in my case its sda for the compleet drive not sda1
so enter rpi-clone sda or rpi-clone sdb
and be aware that you do this as root user
su -
and in my case under debian jessie the usb drives are mounted onder /media/pi
Be aware that al the data thats on the drive wil be overwritten by rpi-clone
billw
Fri Sep 09, 2016 3:48 pm
Yes, you should give a disk name like sdb and not a partition name like sdb1.
I just updated rpi-clone in git to check if a disk name ending in a digit was entered
and it will now warn you that you may have entered a partition name instead of
a disk name.
https://github.com/billw2/rpi-clone
JMK8
Sat May 13, 2017 10:22 am
I'm trying to clone one 8GB SD card to a slightly smaller 8GB SD card with V1.5 of rpi-clone and I get this error - any ideas.
Thanks in advance, JohnK
Allocating group tables: done
Writing inode tables: done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
/dev/sdb is initialized and resized.  Its partitions are:
Error: Can't have a partition outside the disk!
