PolyPV
New audio DAC and class D amplifier with great flexibility
Thu Sep 08, 2016 12:18 pm
Hi all,
you might know us for our first generation PlainDAC and PlainAMP.
We have revised both to give you an even better user experience.
Our new audio modules now come with a special 40 pin ribbon cable connector that removes the hassle of using jumper wires but are still super flexible.
PlainDAC
The new PlainDAC has some nice mounting holes as well as two RCA outputs.
We are using two foil type shunt capacitors and there are two ultra-low-noise LDO's for best audio performance.
The DAC chip is a PCM5121 from Texas Instruments which offers a great sound and has integrated volume control.
All inputs and outputs are protected using TVS diodes for superb ESD immunity.
Two GPIO's from the DAC can be accessed on an unpopulated pin header.
View it in our online shop https://polyvection.com/shop/plaindac/ and see the datasheet https://polyvection.com/wp-content/uplo ... asheet.pdf if you like to know more.
PlainAMP
The PlainAMP was completely reengineered and it uses the same amplifier chip as the older PlainAMP (TAS5756 from TI).
Now there is a DC/DC converter onboard for powering even the RPi 3B under heavy load without the need of a separate 5V supply.
Furthermore there are now some special audio inductors as well as foil type filter capacitors for an even better sound.
Some advanced protection features were integrated as well. Overvoltage, ESD and back powering protection, as well as a resettable fuse and an I2C temperature sensor next to the amplifier IC.
There are some new kind of speaker and power connectors for a perfect and durable connection. PlainAMP now also ships with a barrel jack adapter and two speaker wires.
The mounting hole are partly compatible with the RPi ones. So you can install the PlainAMP directly on your Raspberry.
Or use the flexibility of the ribbon cable and mount it where you have some space for it.
See it in our online shop https://polyvection.com/shop/plainamp/ and view its datasheet https://polyvection.com/wp-content/uplo ... asheet.pdf for more information.
Raspberry Pi 40 pin adapter
To make you life even easier we have engineered a special "40 way pin header to ribbon cable" adapter that can be easily mounted on your Raspberry. There are also some mounting screws and spacers included.
Visit it in our shop https://polyvection.com/shop/plaindac-rpi/ and see the install instructions https://polyvection.com/wp-content/uplo ... _Guide.pdf
All of our products are made in and will ship from Germany.
If you have questions just drop me a message or visit our forum at https://polyvection.com
All the best,
Philip.
