So I have a pi for home purposes, and I want it to be able to survive a power loss.
I also have a spare anker 10000mah battery. A while ago I contacted Anker and they said that one could, but should not daisy chain charge with them (i.e dont have a wall wart powering the Anker and then the Anker powering a device) as it doesn't have pass-through and so the batteries are continually charging/discharging
So the solution I dreamed up was the following
Get a wall wart with two USB sockets
Get a cable such as this (Y cable with 2xUSB A and 1x USB micro) http://www.netstoredirect.com/startech- ... 0wod9-ACFw
Get a normal USB Micro cable
Plug the normal micro cable from wart socket 1 to the Anker
Plug one USB A from the Y cable into the remaining wall socket
Plug the other USB A from the Y cable into the Anker
Plug the UBS Micro from the Y cable into the Pi
Would this work or would the Pi just simultaneously take power from the wall and the Anker, thus defeating the whole point?
