solo2500
Time stamp to log file?
Sat Sep 03, 2016 6:44 pm
I would like to add a time stamp to a ftp.log file every time I send a file. I'm using a cron job to send the file every 5 minutes using the following:
1,6,11,16,21,26,31,36,41,46,51,56 * * * * /home/pi/imagesend_scr1 >> /home/pi/ftp.log 2>&1
1,6,11,16,21,26,31,36,41,46,51,56 * * * * /home/pi/imagesend_scr1 >> /dev/null 2>&1
Is there a simple (elegant?) way to do this?
THANKS ALL!!!
I'm a total novice, non-programer (...basically a hack.)
pcmanbob
Re: Time stamp to log file?
Sat Sep 03, 2016 6:56 pm
you can replace
with
*/5 * * * *
and it will run
2016-09-03 19:00:00 UTC
2016-09-03 19:05:00 UTC
2016-09-03 19:10:00 UTC
2016-09-03 19:15:00 UTC
2016-09-03 19:20:00 UTC
if that is what you are talking about by more elegant
solo2500
Sat Sep 03, 2016 7:41 pm
Yes.. quite a bit more elegant... thanks.
But I would actually like to add a time stamp to the output of : imagesend_scr1
pcmanbob wrote:you can replace
with
*/5 * * * *
and it will run
Sat Sep 03, 2016 7:53 pm
Does it have to be on the x1 & x6 minutes? Or can it run on x5 and x0 minutes?
You could use Bob's option and include a sleep(60) in your script.
solo2500
Sat Sep 03, 2016 8:04 pm
I think you guys may be missing the point (or more likely I'm doing a poor job of articulating the question... ) The output of the ftp script I'm running has no time information... I'd like to know what time the connection information occurred. I would like to insert a time stamp into the log file whenever a log message is generated.
Thanks again!!!
DougieLawson wrote:Does it have to be on the x1 & x6 minutes? Or can it run on x5 and x0 minutes?
pcmanbob
Sat Sep 03, 2016 8:22 pm
if you wanted to output a time stamp to your log file you could do this.
you could add this to your script.
current_time=$(date "+%H:%M:%S")
echo "Executed at $current_time" >>/home/pi/ftp.log
you could even create a start and finish time if you wished.
start_time=$(date "+%H:%M:%S")
your existing script goes in here
end_time=$(date "+%H:%M:%S")
echo "Started at $start_time" >>/home/pi/ftp.log
echo "Ended at $end_time" >>/home/pi/ftp.log
solo2500
Sat Sep 03, 2016 10:05 pm
Works perfect!!!
THANKS!!!
Return to “Beginners”
